Chipped 320 ECU in a 325?
Brian28
Post Tue Dec 06, 2011 7:22 am
I'm converting an early 325 engine to later management and putting it into a 318 shell. I have a remapped chip for a motronic 325, if I put this into a 320 ECU (the engine loom donor is a 320) will it run the 325 Ok?
Brian
For sale - E30 320i racer project - sold.
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Dec 06, 2011 7:30 am
As long as the ECU is a Motronic 1.3 (1988 onwards), then you should be fine.
Check your ECU part number here:
http://www.e30zone.net/e30zonewiki/index.php/ECU
mrLEE30
Post Tue Dec 06, 2011 7:35 am
Only thing to check is if the ECU is for an auto or manual, mainly as idle speed is different.
Brian28
Post Tue Dec 06, 2011 8:00 am
Thanks chaps :thumb:
mrLEE30
Post Tue Dec 06, 2011 8:12 am
after a re-read it is the chip that controls idle speed anyway, so if you have replaced the chip in an ECU from a Motronic 320 with a chip for a 2.5 it will work fine.
