if any one spots something i need to do or should be aware of then don't be shy
here we go again .
in this pic the smaller pipe with the jubilee clip goes to the throttle body,now do i blank this off as i'm getting a complete m50 intake?
brown temp sensor needed here yeah ? and the coolant hose to the right goes to the throttle body or there abouts do i blank this off ?
is there a plug for the injector rail, or do i send that to Dan [injector rail] not injectors.when i send the loom.
basically the loom is still attached to the m52 inlet manifold via the injector loom .
also some kind of breather from the dipstick [blocked] do i blank this off or do i need an e34 dipstick tube ? the stick itself is broken at the top so can't be used and is this 7 series sump good to go in an e30 ?
got
clio servo
m20 clutch and lightened fly,starter motor
e36 engine arms
i have a list that covers most if not all parts needed and is in progress.
so just a few small questions to begin with .
