spark but no fuel
randomspeedfreak
Post Tue Nov 29, 2011 11:22 pm
right, got the car turning over today.
i think ive got the ews right now, as im getting a spark and can hear the module click in the acc position
i dont think im getting any fuel though
the fuel pump runs when the key is in the run position, it dosent prime it just runs and runs.
you can feel the inlet and outlet of the fuel rail have fuel circulating, but i dont think the injectors are firing at all.no smell of fuel no spluttering just straight up nothing.
HELP! where do i start!?
Barx325i
Post Tue Nov 29, 2011 11:30 pm
silly one, do you have the flow correctly plumbed?
randomspeedfreak
Post Tue Nov 29, 2011 11:34 pm
Barx325i wrote:silly one, do you have the flow correctly plumbed?
i think so..... would it have this affect if it was incorrect?
ill double check tomorrow
any other possibilities?
cheers
Jimbob
Post Tue Nov 29, 2011 11:36 pm
Yes, and this appears to be a common thing when it comes to first time firing it up - I'll bear this in mind when I get that far!
randomspeedfreak
Post Tue Nov 29, 2011 11:38 pm
ive just realised i think i put what should be an earth to power!
jesus i hope i havent fried anything.
im trying to remember if i did but i recon that could be the culprit
any other suggestions still welcome
e30-EVN
Post Wed Nov 30, 2011 1:20 am
Fuel lines the wrong way round is such an easy 1 to get muddled... Hands in the air, I've done this lol
Fuel return from fpr...........
Bad ews will give no fuel and spark. Car will turn but not fire!
randomspeedfreak
Post Wed Nov 30, 2011 10:41 am
wait a minute woah woah woah, the fpr is on the RETURN end of the fuel rail?!
e30-EVN
Post Wed Nov 30, 2011 12:20 pm
Yes mate, fuel supply to the rail- circulates the fuel rail - returns via the fpr to tank......
Its the fpr that keeps fuel pressure "in" the rail ect 8)
randomspeedfreak
Post Wed Nov 30, 2011 8:54 pm
Right down the garage. I hadn't made a mistake with the brown wire, it is earthed which is good! But on the other hand i'm not getting any fuel pressure at all - the pump hasn't even hinted at running.
I've measured the voltage at both the e36 pump relay and at the pin that goes to the e30 relay (should I have both by the way?!) and they both rise to 12 volts momentarily when in the run position then drop to 0.
When cranking both then drop to about 9 volts but nothing from the pump.
While all this is going on the idle control valve is buzzing constantly, from the moment you switch to the run position till 6 seconds after everything is off.
I don't know where i've gone wrong please help if you
Cheers,
Matt
randomspeedfreak
Post Thu Dec 01, 2011 10:23 am
anyone please! :cry: :cry: :cry:
randomspeedfreak
Post Thu Dec 01, 2011 11:17 am
ive got the e36 wiring diagrams out, my loom came from an auto, so what is the transmission control module?
is this something i will have? how does it work?
randomspeedfreak
Post Thu Dec 01, 2011 1:07 pm
okay it appears that the traction control module, tcm, is what i / we have been calling the auto ecu.
is the only thing that is needed is to remove the auto ecu? as if you look to page 161 here:
http://wedophones.com/Manuals/BMW/1996% ... Manual.pdf
it looks like the tcm controls a switch for the fuel pump
Post Thu Dec 01, 2011 1:10 pm
I assume you have checked for power at the fuse?
randomspeedfreak
Post Thu Dec 01, 2011 1:23 pm
DanThe wrote:I assume you have checked for power at the fuse?
8O
i checked at the terminal of the c101. pin 13 i think. would that be the same?
Post Thu Dec 01, 2011 1:42 pm
That would be one side of the fuse yes, but have you checked the other side, ie between the fuse and pump?
randomspeedfreak
Post Thu Dec 01, 2011 2:05 pm
DanThe wrote:That would be one side of the fuse yes, but have you checked the other side, ie between the fuse and pump?
i havent,
how would i go about that?
*edit*
remove the fuse then test the voltage drop across from each pin when in the run position?
randomspeedfreak
Post Thu Dec 01, 2011 5:06 pm
why do i still have 2 relays for the fuel pump?
surely i should have done away with the m52 circuit and use the standard e30 relay using the signal from the ecu?
Post Thu Dec 01, 2011 5:48 pm
You seem very confused :)
The fuel pump is switched via one relay which is part of the engine loom, the signal goes from the relay through Pin 13 of the C101 to fuse 11 then down through the car to the fuel pump.
randomspeedfreak
Post Thu Dec 01, 2011 6:27 pm
DanThe wrote:You seem very confused :)
i am very confused! :cry:
i think my confusion is because i have more than one relay seemingly performing the same task! i havent seen any mention of taking a relay out before!
so what happens to the relay that was previously turning the fuel pump on before i did the conversion? surely this is sitting in the fuse box and breaking the circuit as it is still connected, but not being switched on by anything?
right so i am to use the m52 relay and should make a circuit like this (pretty picture! :) )
thats it? no other complications?
dan what does it mean if i find no power on the 'pump' side of the fuse?
Post Thu Dec 01, 2011 6:39 pm
The fuel pump relay would have been on your original E30 engine loom, there is no second relay, maybe a picture would help?
The way id test it is to bridge the pump relay (thick Red to thick Green/Purple) and see if the pump spins, if it doesnt check for power at the fuse (easy job) if you have power there then check for power at the pump itself
Green
Post Thu Dec 01, 2011 7:00 pm
Can you hear the pump prime when you put the ignition on? Have you tried removing the fuel lines from the fuel rail and crank it over, make sure the lines are in a bottle or something to catch the petrol. If you're getting fuel through that's not your problem.
randomspeedfreak
Post Thu Dec 01, 2011 7:06 pm
DanThe wrote:The fuel pump relay would have been on your original E30 engine loom, there is no second relay, maybe a picture would help?
ohhhh i seeeeeeeeeeee
okay that makes it much simpler!
is that pretty picture correct then dan?
randomspeedfreak
Post Thu Dec 01, 2011 7:07 pm
Green wrote:Can you hear the pump prime when you put the ignition on? Have you tried removing the fuel lines from the fuel rail and crank it over, make sure the lines are in a bottle or something to catch the petrol. If you're getting fuel through that's not your problem.
the pump does nada, we have the lines off in the bucket it dosent even hint at running
randomspeedfreak
Post Thu Dec 01, 2011 7:08 pm
anyone got any ideas as to why my idle control valve is constantly buzzing?
how does the fuel pump know when it has reached the correct pressure?
Post Thu Dec 01, 2011 7:11 pm
Fuel pump runs continuous regardless of pressure, the ICV should buzz with ignition on
randomspeedfreak
Post Thu Dec 01, 2011 7:28 pm
DanThe wrote:Fuel pump runs continuous regardless of pressure, the ICV should buzz with ignition on
sweet im buzzing to get down there tomorrow a.m. now!
should i wire the circuit as per the (rubbish) diagram dan?
out of interest what does the other relay, also green, that sits right next to the fuel relay, do?
Green
Post Thu Dec 01, 2011 7:53 pm
When you turn the ignition on, can you hear the EWS click first?
IIRC this was stopping mine from firing up the first time.
e30-EVN
Post Thu Dec 01, 2011 8:37 pm
thats a myth mate..
ive had 3 sets and 2 of them did not click. the other 1 did :mad:
Post Thu Dec 01, 2011 8:51 pm
Yeah im not sure of the exact date but I think its 1998 when they changed the module and you dont get a click, the ones that dont click usually have a purple plug
randomspeedfreak
Post Thu Dec 01, 2011 10:08 pm
yeh i think my ews is wired okay as im getting a spark :)
i do get that click aswell
should i wire the circuit as per the diagram dan?
Baurluvva
Post Fri Dec 02, 2011 1:48 pm
I too am having issues with the fuel pump not working.... Fuse is ok.
Do I have to remove the relay off e36 as this is still attached?Image
Post Fri Dec 02, 2011 2:02 pm
The other relay is the DME, switches power to the loom when ignition comes on
The third relay, on the left in baurluvva pic above, is an addition to later looms, it switches ignition feed to the loom
Post Fri Dec 02, 2011 2:08 pm
All three relays are part of the engine loom. The three sockets (only two relays usually fitted) come out with the original engine when you remove it, and the three new relays go in as part of the engine loom of the new engine.
The relays are the main DME relay, the fuel pump relay and the lambda sensor heater relay.
Linking together pins 30 and 87 of the fuel pump relay's base should make the fuel pump run continuously, whatever engine you have, apart from a carb. M10.
Baurluvva
Post Fri Dec 02, 2011 3:43 pm
Tried bridging those 2 - nothing!
Also trying to fit m50 manifold but am stumped with this connector - 3 pin!!!
e30-EVN
Post Fri Dec 02, 2011 4:00 pm
That looks like the plug for ICV mate........
