Panic!!!
b12rlw
Hey folks, will an auto m20 engine fit straight onto a manual 'box? (using the manual clutch and flywheel arrangement) What i'm getting at is... are the cranks the same at the transmission end? Cheers!
eko
- Old timer
Yes but youll need to fit a thrust bearing into the crank first,cost about a tenner
b12rlw
mucho gracia!! the cranks coming out to have the bores honed and the pistons decoked. Is the thrust brg the brg between cyls 5&6?
mrLEE30
no its the bearing between engine and clutch assembly, the autos dont have them so to fit a clutch/man box you must add the bearing.
You also need to consider that the prop shafts are different between the auto, the Getrag 240 manual and the Getrag 260 manual - or at least are different lengths.
you also need to bypass the start inhibitor system as found on the auto box ECU loom
b12rlw
I've got a boosted manual running megasquirt with a knackered head gasket which is donating parts to a nice new auto lump which is being rebuilt ( later low comp model) I've stripped the auto engine yesterday and last night had a thought that the internals are different. That's cool gents, I'll just swap everything over when the old dink gets pulled! Cheers again!!
