Panic!!!
b12rlw
Post Wed Nov 30, 2011 10:04 pm
Hey folks, will an auto m20 engine fit straight onto a manual 'box? (using the manual clutch and flywheel arrangement) What i'm getting at is... are the cranks the same at the transmission end? Cheers!
eko
Old timer
Post Wed Nov 30, 2011 10:07 pm
Yes but youll need to fit a thrust bearing into the crank first,cost about a tenner :wink:
b12rlw
Post Wed Nov 30, 2011 10:18 pm
mucho gracia!! the cranks coming out to have the bores honed and the pistons decoked. Is the thrust brg the brg between cyls 5&6?
mrLEE30
Post Thu Dec 01, 2011 5:28 am
no its the bearing between engine and clutch assembly, the autos dont have them so to fit a clutch/man box you must add the bearing.
You also need to consider that the prop shafts are different between the auto, the Getrag 240 manual and the Getrag 260 manual - or at least are different lengths.
you also need to bypass the start inhibitor system as found on the auto box ECU loom
b12rlw
Post Thu Dec 01, 2011 8:51 am
I've got a boosted manual running megasquirt with a knackered head gasket which is donating parts to a nice new auto lump which is being rebuilt ( later low comp model) I've stripped the auto engine yesterday and last night had a thought that the internals are different. That's cool gents, I'll just swap everything over when the old dink gets pulled! Cheers again!!
