compact diffs
321gazza
Will a compact or even a mz3 diff fit straight onto my e30 rear subframe and could i use my e30 driveshafts.
pac1982
I know you need a E30 diff for a compact so my answer would be yes.
Not many good diffs on compacts though thats why most people put E30 ones on
blue30
I have a Z3 2.8 diff on mine, I it was a while ago but I think I used an e30 325i back plate and flanges.
321gazza
Would the back plate from my small case 4.10 diff cover fit a z3 diff and my driveshafts.
bimanut
If blue30 used a 325 back plate then no your 4.10 wont fit.
The 325 diff is a medium case and as you say the 4.10 is a small case and have different bolt patterns.
blue30
Yes its the larger case diff you'll need bits off. Thinking back mine came without flanges so I don't know if Z3 flanges fit, I had some 325 flanges so used those. Can't honestly remember if I had to change the back plate or not but it would definitely be the 325 one if you do. You might not need to as the subframes are nearly the same. I know the old 525e diffs need a back plate change as they put the bush/mount in a different place. I ran one of those for a while (2.97) with my m50 swap till the Z3 LSD came up cheap (3.15).
I have a Z3 2.8 torsen slipper diff. in use, and, as far as I can remember, no backplate change was required.
Mine came with one flange missing, and now sports one Z3 flange and one E30 325 one. They are not identical - there are differences in the shield for the oil seal, but there are interchangeable.
321gazza
All sounds complex to me, just after a diff that will cope with 300 bhp and have a lsd that will bolt straight onto the e30 subframe and a ratio of about 3.73 or 3.64 or 3.56.
blue30
Z3M diff will take more power than that all day long, it has a big finned cover to get the heat out but the ratio's wrong for you.
I think I'm right in saying that the compact and Z3 diffs are all much lower ratios than that
Unless you're sidestepping the clutch on slicks you might be best getting a 3.64 E30 diff rebuilt and sticking a Z3M cover on it. Think there's a bloke on here who does good value rebuilds but can't remember his name at the mo...
321gazza
Sounds good to me just need to get his name or number.
penton08
Gareth is the man you need
Andyboy
- Alpina Colada
The Compact/Z3 diffs are E30 casings with E36 internals. The output flanges have the locating circlips in different places so that whilst the flanges will swap over, they won't fully 'locate'. That shouldn't be a problem, although it's not really ideal.
321gazza
How do i contact gareth, or will a 325i diff with lsd be ok.
