OBC question please?
csl
Post Sun Nov 20, 2011 3:14 pm
Had a go at fitting the obc to my car yesterday.Followed the wiki method thats on here and everything went perfectly....until the last bits.
Im left with 3 wires that i carnt find a home for.
1st is in the engine bay...this is a black plug with brown wire and green tracer + a brown wire into it.
The other 2 are in the interior behind the glove box..these are a black plug with brown wire and green tracer + red wire with white tracer into it AND a white plug with green wire + green wire with red tracer into it.
I thought these last 2 went into the white wireing block of connecters but carnt find a home with the correct size pins?
Point me in the right direction please? I ve used the search btw,but every time i read a post i have to type the same search in again.
Post Sun Nov 20, 2011 9:29 pm
Green and green/red are the immobiliser plug which fits to a socket hanging from the loom above the glovebox, but my advice is don't bother. There will already be a plug in this socket.
Other two: These are the plugs for some kind of switch on one of them, and something that is controlled by that switch on the other. I've no idea what this switch and switched object is, as
I've never seen them used, or if they have ever been used in any market.
You should also have a single white plug on a yellow wire somewhere that isn't used.
csl
Post Sun Nov 20, 2011 9:40 pm
Brianmoooore wrote:Green and green/red are the immobiliser plug which fits to a socket hanging from the loom above the glovebox, but my advice is don't bother. There will already be a plug in this socket.
OK,thankyou for the response Brian.....so just to confirm.....the only one i need to connect(should i choose to)is the green and green/red, as the rest are not used anyway?
csl
Post Sun Nov 20, 2011 9:43 pm
Also,i take it that the original anolog clock connector is now to be redundant and tucked back out of sight into the loom?
Post Sun Nov 20, 2011 9:58 pm
Correct on all counts!
Plugging in the green - green/red may not be straightforward, depending on what you find already plugged into the socket.
csl
Post Sun Nov 20, 2011 10:28 pm
Brianmoooore wrote:Correct on all counts!
I see.Reading the wiki it just sounded like it was a straight plug in.Oh well,i shall see exactly what is in the connection already!
csl
Post Sun Nov 20, 2011 10:35 pm
Also,if someone has a photo(or would take one for me?) of the exact whereabouts to fit the horn and guard,id appreciate it. :D
I know its above the n/s fog light,but as to how it lies im un-sure and want to get it right.
Post Sun Nov 20, 2011 10:53 pm
csl wrote:Also,if someone has a photo(or would take one for me?) of the exact whereabouts to fit the horn and guard,id appreciate it. :D
It fits directly underneath where the ABS pump fits. All the holes are there, so you should be able to line up the holes on the guard to see exactly where that fits, and then work out which hole is for the horn, so that it fits inside the guard.
csl
Post Mon Nov 21, 2011 9:37 pm
Thanks for the info Brian,i shall get back into it on my next day off...whenever that will be! :(
poolnoodle
Post Wed Nov 23, 2011 4:56 am
The alarm function is pretty useless and causes more problems than solutions. It can be easily overridden by disconnecting the power!
I agree with Brian...don't bother
csl
Post Sun Nov 27, 2011 7:49 pm
I had a bit of time spare today,so carried on with it for a short while.
Another question though,if i may.....with (battery connected)and ignition off/keys out, the "----uhr" symbols can still be seen,although not illuminated with back light....i take it this would be normal, for the clock operation to function?
mark_i
Post Sun Nov 27, 2011 9:43 pm
yep, thats how the OBC works when the ignition is off.
set the time and you can see the time change even when the keys are out.
csl
Post Tue Nov 29, 2011 12:19 am
mark_i wrote:yep, thats how the OBC works when the ignition is off.
OK.Thanks mark. 8)
