si board batteries
andy523
Post Tue Nov 15, 2011 8:48 pm
where can i buy replacement batteries for the si board?
andy523
Post Wed Nov 16, 2011 7:17 am
i cannot find them anywhere, i suppose it would be better if i knew what i am lookin for.
the old batteries are varta ni-cd krh 15/51 so what do i look for , eg volts, capacity etc
badboye21
Post Wed Nov 16, 2011 8:19 am
i bought mine from www.batterysity.eu cost me £14 inc postage for the pair i just searched by the part number on the battery.
andy523
Post Wed Nov 16, 2011 8:39 am
there is no site at that address !
rover-2000
Post Wed Nov 16, 2011 8:50 am
Maplin sell them, so I'm told. They must be the solder tab type and the same type of battery.
Kind regards
John
1989 320i Touring
1993 E34 525i SE Touring
1979 Porsche 924 Lux
1982 Porsche 924 Lux
1985 Porsche 944 Lux
Post Wed Nov 16, 2011 8:51 am
Post Wed Nov 16, 2011 9:15 am
CPC-Farnell, part # BT04235 at £1-79 each will do the job perfectly.
These are tag ended AAA NiMH cells that are physically smaller than the originals (but with a higher capacity), which will allow you some extra room to fit them in. The tags aren't the same as the originals, so note which end is +, and solder on some short lengths of wire to the tags to fit them in.
Beware of carriage charges on orders under £45!
They used to list a 2/3 length AA cell that was ideal, but that appears to be no longer listed.
andy523
Post Wed Nov 16, 2011 3:34 pm
had a look on the site, why couldnt i use a AA with a capacity of 1300 or are these to strong
whats the original capacity
what about the below battery
varta BT04108 on the cpc site
Post Wed Nov 16, 2011 4:30 pm
Original battery is only 500mA/hr, so the 800mA/hr AAA one I've suggested is more than adequate.
The problem with using AA length batteries (50mm length) is that the tags are different from the original batteries, and the wire links you will have to solder on to fit them are in danger of shorting to adjacent components. Using a shorter battery solves this problem completely.
The battery only has to maintain the SI indicator memory at any time that the main car battery is disconnected, so even the original 500mA/hr cells are probably overkill.
andy523
Post Wed Nov 16, 2011 4:43 pm
ok thanks brian, its just that the originals are AA but i will give the others a go.
andy523
Post Sun Nov 20, 2011 4:55 pm
got the batteries that brian recommended fron cpc, soldered them in yesterday. fitted the cluster today, started the car an let run for a while. re-set the inspection lights with a cheap ebay item and hey presto, full green lights and a working rev counter and water temp gauge.
thanks brian
Rares
Post Sat Nov 26, 2011 1:26 am
very good info here guys, thanks. this also helps me in time of need. i know now what i need to do. thank you for the wisdom.
Clean is not a competition. It's a way of life
