Valve clearances (again)
James90
Post Sat Nov 19, 2011 5:39 pm
Sorry for starting another thread on valve clearances - I have done a search which as taught me all I know so far but have a few questions I couldn't definitively find the answer to.
Engine is an M20B25
I assume what you do 1 cylinder at a time - both valves?
What I understand:
clearance on stone cold engine is 0.25mm and should have some drag when sliding feeler in and out.
When the cam lobe is pointing all the way down this means the valves are closed (TDC?)
So if I have cylinder 1 cam lobe pointing down I have to use the rule of 7 which means that I now adjust the clearance on cyl 6?
cheers
'88 325i Auto Chromie Cabriolet in Alpine White
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Nov 19, 2011 6:09 pm
James90
Post Sat Nov 19, 2011 6:15 pm
I have looked at that, but that suggests that you adjust the each valve when it's lobe is pointing directly down - When doing a search on here I read conflicting views?
leeparkes
Post Sat Nov 19, 2011 6:43 pm
I do each valve individually starting at cyl 1, maybe cyl 5 exhaust will be shut but work on one cyl at a time and you wont go wrong.
Yes, the rocker is adjusted with the cam lob down, ie valve shut.
James90
Post Sat Nov 19, 2011 6:51 pm
Right so cyl 1 inlet valve lobe down. adjust. Rotate crank. cyl 1 exhaust lobe down. adjust. Rotate crank. Cyl 2... etc etc.
Sorry I'm being thick but this is the first motor I've played with that doesn't have hydraulic ones!
215m3
Post Sat Nov 19, 2011 8:56 pm
Hi James
Create a spreadsheet with the cylinders 1 to 6 and exhaust and inlet. When the pointed end of the lobe is pointing towards the sky, the valve will be shut. Start at the front of the engine, measure the gap with a feeler and record on the spreadsheet.
Look down the cam to find the next lobe pointing towards the sky, then rotate and repeat until they are all done. On the spreadsheet add the gap allowance and then see which are to wide, too narrow or in allowance. Swap or replace those out with the allowed tollerance.
HTH's
Toby
1987 E30 M3 S14 Turbo
1971 V12 E type Roadster
ross2009
Post Sat Nov 19, 2011 9:37 pm
sorry toby but thats not right the lobe has to be facing down for the valve to be shut if the lobe is pointing up that means its on cam and the valve will be fully open
Turbo M20
v8 project 6.0 twin turbo
Barx325i
Post Sat Nov 19, 2011 9:49 pm
umm, no:
the lobe (centre line) facing up as identified in the pic below in comparison to the mid point of the base circle - should be pointing upwards, inline with the valve stem
ross2009
Post Sat Nov 19, 2011 9:51 pm
yes which means the valve is then open the valve needs to be shut to do valve clearances which needs to be pointing down
Turbo M20
chh137
desmodronic (spelling) valve gear on a M20B25 ?
Jim320i
E30 Zone News / COTM Team
Post Sat Nov 19, 2011 9:53 pm
You sure Barx? If so, my Engine is foook 8O
http://www.e30zone.net/e30zonewiki/inde ... M20_engine
Step 6 says different...
Thats how I have set mine up, same as a few other zoners cars which I have done... :mad:
ross2009
Post Sat Nov 19, 2011 9:55 pm
if i adjusted mine like that they would be clattering like a bitch if not brake some thing
Turbo M20
leeparkes
Post Sat Nov 19, 2011 10:09 pm
Rocker needs to be touching the middle of the base circle.
:mad:
ross2009
Post Sat Nov 19, 2011 10:16 pm
leeparkes wrote:Rocker needs to be touching the middle of the base circle.
:mad:
+ 1 on that
Turbo M20
Post Sat Nov 19, 2011 10:19 pm
M20 engine has rockers, so the cam opens the valve when the lobes are pointing up! As a consequence of this you adjust the clearance on a particular lobe when it's pointing down.
When 6 is pointing up; i.e the valves on 6 are open, adjust 1.
Turn the crankshaft forwards 60 degrees, with a 22mm spanner on the crank bolt, and the valves on 2 will be open, so adjust 5. Keep going, 60 degrees at a time, until you have turned the crank two full turns and the job will be done.
If you're not confident of knowing what a "sliding fit" is for the feeler gauge, check with another one 1 thou' thinner, which should go in easily, and another one 1 thou' thicker, which should need forcing in.
James90
Post Sun Nov 20, 2011 12:30 am
Right, I think I know what I'm doing now chaps thanks for the input!
Will have a go tomorrow.
