misfire at 4k RPM
domkolo
Post Fri Nov 18, 2011 3:37 pm
Hi there,
I'm the guy that has started this thread a while ago, my problems are exactly the same,
i changed all the ignition parts and it's still the same, I told my mechanic about the cam, he said it wouldn't be that because the engine is not tappetty,
it's at exactly 4k rpm, it sounds like it splutters, then changes up a gear, then re sets itself after losing a bit of power, mine is an auto though but from what you've described it's exactly the same problem as mine has.
It doesn't bother me too much because i never floor it anyway but it's pretty annoying and obviously doing the car no good, i'd like it sorting but with crimbo round the corner I can't be replacing parts willy nilly bro so any help when you've sorted it would be much appreciated!
Could just be paranoid but i feel like mine is using more fuel than it should aswell cos i'm getting the same mpg out of my 325 so something can't be right.
domkolo
Post Fri Nov 18, 2011 3:43 pm
Grrrmachine wrote:Sure it's not the same issue as in the other thread?
http://www.e30zone.net/modules.php?name ... c&t=208872
yes it is this issue, I still need it sorting too, blingsta has just described it better than i have
Post Fri Nov 18, 2011 6:33 pm
domkolo wrote: I told my mechanic about the cam, he said it wouldn't be that because the engine is not tappetty
An unjustified assumption on this engine!
blingsta
Boost Junkie
Post Fri Nov 18, 2011 6:37 pm
sorry Brian, what does the above mean? are you assuming the cam to be worn?
Post Fri Nov 18, 2011 6:45 pm
the M40 is renown for cam wear especially on badly serviced/ill treated cars,
the lobe on the cam wears away and when the cam lobe/followers have worn the valves aren't depressed properly, this leads to only revving up to around 4-5k,
IIRC a kit is around £150 + fitting
Post Fri Nov 18, 2011 6:46 pm
I've no idea if your cam is worn without seeing it, but the fact that the "engine isn't tappetty" is no indicator that it isn't.
blingsta
Boost Junkie
Post Fri Nov 18, 2011 6:48 pm
ok chaps.. many thanks for the input... considering that everything else has been changed or replaced... the ONLY other thing to go ahead and change is the cam...
i'll keep my fingers crossed :wink:
Post Fri Nov 18, 2011 6:57 pm
Just run a finger across the top of the cam lobes. There's a narrow bit (not polished) each side that doesn't get used. If there's the slightest step down into the polished bit, the cam is worn.
blingsta
Boost Junkie
Post Fri Nov 18, 2011 7:02 pm
will update once cam is changed for a good 2nd hand one..
or is a new one a better option?
blingsta
Boost Junkie
Post Fri Nov 18, 2011 10:02 pm
Brianmoooore wrote:Just run a finger across the top of the cam lobes. There's a narrow bit (not polished) each side that doesn't get used. If there's the slightest step down into the polished bit, the cam is worn.
Brian.. any chance you can point out the bit i need to check for the damage pls.. i found this picture on google if it helps?
http://www.fabdirect.com/BMW_Parts_imag ... 9580_2.jpg
Post Sat Nov 19, 2011 2:05 pm
Plenty of worn cam lobes to be seen here:
http://tinyurl.com/bromhrw
