Had a bit of a nightmare/set-back yesterday on the rear disc conversion.
Started to build up what we thought were two identical trailing arms (we had a third which was rotten) only to find that one aparently came from a pre-09/85 car and uses a different size bearing, my fault completely, should have done more investigation pre-purchase. I must admit we were a bit surprised these smaller bearings only lasted for a few months of production.
So, ideally we want to use later arms... Both of the hub flanges we have are for the smaller bearings, so we'll be needing them as well. Although when stripping down the rear yesterday I noticed the ones on the drums look identical so I'm hoping we can use these, does anyone know?
Also, the dive shafts, are they the same for early/late bearings? I can't imagine them being different.
We have found somewhere with a 1991 318is Cab which the breaker thinks has rear discs and I'm inclined to agree, so we'll be stripping that next weekend. I guess you can never have too many rear suspension parts
Nothing's ever simple is it!?
Rear Bearings / Flanges etc.
redcar
318is cab? No such thing produced.
Probably a 318i I dont think those had rear discs
greggers
Yeah you're right, I've just looked on real oem and they don't exist.
However if I put in a '91 cab, it does come up as having rear discs, so I think I was at least half right.
redcar
really? wouldn't trust in realoem 100% though, also their diagrams are a bit mis leading and some of the engine stuff regarding the 318is m42 is wrong.greggers wrote:Yeah you're right, I've just looked on real oem and they don't exist.
I was under the assumption only tourings and 325is and 318is had rear discs.
greggers
Well the breaker is only down the road and he's going to start stripping the bits we've asked for tomorrow, pretty sure he'll let us know if they aren't discs tomorrow. If not I'm sure we'll find some somewhere.
When I put in my model (87 320i) both drums and discs come up as an option. For a '91 318i cab I only get one option, discs. For a '91 318i coupe I get discs and drums again.
The other odd thing of note is that a 318i cab was only available from mid 1990 on, which makes me think BMW might have fitted discs to it for the whole time it was available.
From what I can work out, these reduced sized trailing arms can only have come from a pre-85 323i
All cabs, tourings and 325 saloons have rear discs, as do any lesser E30 that was ordered with ABS.
greggers
Music to my ears, cheers.Brianmoooore wrote:All cabs, tourings and 325 saloons have rear discs, as do any lesser E30 that was ordered with ABS.
