e30 m52
ante3025
Post Tue Nov 08, 2011 11:02 pm
hi i am puting a 2.8 m5e engine in to my e30 and i am not sure on wot to get past the ews is ther a way i can bypass it ?.
Post Tue Nov 08, 2011 11:04 pm
get in touch with a member on here called DanThe, he can de-EWS the ECU for you. Or he can sort you out with a plug & play loom on an exchange basis so you can keep the EWS
Post Tue Nov 08, 2011 11:05 pm
First question is "why do you want to bypass it?"
If you definitely want to, then contact DanThe.
leeparkes
Post Tue Nov 08, 2011 11:07 pm
Keeping EWS is a good thing imo.
ante3025
Post Tue Nov 08, 2011 11:50 pm
i am not that gd with wiring lol i dont thin i have got all the bits i need for thw ews to work ?
Post Wed Nov 09, 2011 12:38 pm
For the EWS to work you need the following all from the same donor vehicle
ECU
EWS box
Ignition key
I'm useless at wiring too, which is why I bought a plug & play adapted loom from Dan and kept my EWS
ante3025
Post Wed Nov 09, 2011 10:18 pm
this is wot i got with the engine and i got the key
Post Wed Nov 09, 2011 11:43 pm
Assuming they are a matching set, that's what you need.
Also needed are the antenna ring and the small Tx/Rx module, but these can be from any car that has them.
Post Wed Nov 09, 2011 11:58 pm
This is what you need
leeparkes
Post Thu Nov 10, 2011 12:18 am
And this is how its plumbed in.
ante3025
Post Thu Nov 10, 2011 12:50 am
ok just so i get this right wot do i put the violet/white do i put that to the ignigstion and do i just give the red/yellow a constant 12v ?
Wilson325i
Post Thu Nov 10, 2011 11:18 am
Wow! you guys are fantastic, this is how it should be done. This is some very good flowing advice that is not filled with sarcastic a$$ replies that you get in some threads.
Thumbs up guys! :thumb:
Ante3025 unless you have a VERY good alarm then keep the EWS. No way in hell will anyone drive of with your joy when you have the ews chip with you indoors. Unless they are so determined that they show up with their own ews and key and proceed to wire it in outside your house :D
Post Thu Nov 10, 2011 11:36 am
There's some helpful wiring info here dude
http://www.e30zone.net/modules.php?name ... c&t=158933
ante3025
Post Thu Nov 10, 2011 11:04 pm
i am going to keep the ews the onle thing i cant work out on the diagram for the ews is wot i put violet/white wire and wot to put the red/yellow wire to ?
leeparkes
Post Thu Nov 10, 2011 11:34 pm
Im sure violet/white is switched live and red yellow is permanant live.
Not 100% sure though so wait for someone else to post before you go snipping wires. :)
ante3025
Post Fri Nov 11, 2011 8:28 pm
leeparkes wrote:Im sure violet/white is switched live and red yellow is permanant live.
that wot i thought bt i am not to shuer lol
greggers
Post Sun Nov 13, 2011 6:50 pm
Yep, agree red/yellow is permanent. Violet/White is switched (but will work with permanent as well, might drain battery like this though).
ante3025
Post Sun Nov 13, 2011 7:14 pm
sond m8 thank for that i can get that don now thanks for all your guys for all your help and coments i well let u all know how i get on and well post some pic up soon of my e30
