only revving to 4500 rpm?
domkolo
Post Mon Nov 07, 2011 1:33 pm
my 318i auto cab only revs to 4500rpm when i put my foot down, stays at those revs, then changes gear after 2-3 seconds
I've been told a mixture of things like the distributor cap,rotor arm, leads and plugs need changing,
does this problem sound familiar to anyone and would you know what it'd be?
Post Mon Nov 07, 2011 1:42 pm
Tried holding it in gear?
greg124
Post Mon Nov 07, 2011 4:48 pm
worn camshaft, possibly?
Schadenfreude - the German's haven't got a word for that.
Post Mon Nov 07, 2011 7:35 pm
greg124 wrote:worn camshaft, possibly?
This :(
Worn camgear / lifters is the most common reason for an elderly M40 to not pull to the redline . They don't neccessarily need to sound dire to suffer from this ailment either .
Post Mon Nov 07, 2011 7:41 pm
toblerone cam syndrome, :eek:
redcar
Post Mon Nov 07, 2011 11:51 pm
Mine did this, doesn't rev past 5000, then when I shifted, it still spluttered for a few seconds.
Was advised that the camshaft was gone. A chap came up with a funny saying for the noise it made on idle. Tappety it was! Good luck
Post Tue Nov 08, 2011 1:21 am
first off all i would eliminate the autobox with some fresh oil and a new filter.
however if your engine sounds tappety then its 99% going to be a wanker cam
try holding it in gear, my 318i auto changes at 5000rpm but if you hold it in gear goes to revlimit easily. ive yet to change oil and filter.
domkolo
Post Tue Nov 08, 2011 8:43 am
thanks for the advice guys, hopefully pacerpete will be able to make good sense of what the problem is this weekend!
it changes fine when im just plodding along but when i hold it in gear it sits on 4500 and splutters for 2-3 seconds before changing up a gear, then it feels like it's down on power,
I had a chap look at it and the weekend when i had a few neccessary bits done. he said the auto box was fine so i guess it all adds up to be the cam shaft like you guys have kindly advised!
nice one!
AlpineAde
Post Wed Nov 09, 2011 2:57 am
How's your coil, OP?
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Nov 09, 2011 6:39 am
"skeleton wanking into a dustbin" was the phrase used to describe a knackered cam :D
blingsta
Boost Junkie
Post Wed Nov 09, 2011 10:42 pm
is this sorted? ive just started a thread for a mates 318i revving to 4k then misfiring ? its not a auto though... ?? well confused..
