headlight out, its not the obvious.... pls help
e30-EVN
Post Sun Nov 06, 2011 9:33 pm
Went for a drive and a light popped up saying dipped beam. Pulled over and checked it, passenger side out!
Replace with a known working bulb and still not working! I've just checked the fuses and they are all ok.
What is the problem guys? Can anyone help?
T I A
e30-EVN
Post Sun Nov 06, 2011 10:14 pm
Anyone?
By the time I get home from work it will be dark tomoro night so I need to fix this
Post Sun Nov 06, 2011 10:16 pm
Sure the bulb you replaced is a good one??
I've done this too , and replaced with what i thought was a good working bulb, then went through checking fuses etc....., turned out the replacement was fooked too. :mad:
Try another bulb. :D
Sanchez
Post Sun Nov 06, 2011 10:22 pm
put the bulb from the working light into the non working light to see if it is the bulb.
If it still doesnt work go though the wiring.
e30-EVN
Post Sun Nov 06, 2011 10:42 pm
Well what happened was my old bulbs were working fine but as you know they give off a yellowy light so I went out and bought ice white bulbs which I put in and all was good until tonight....
Then I put 1 of my old bulbs straight in but no joy! Its been in the boot in the box the new 1's came in but I guess it could have rolled around and damaged..?...
I will try now
Thank you
e30-EVN
Post Sun Nov 06, 2011 11:01 pm
Guess what boys......... Lol :roll:
Put drivers side bulb in and hey presto!
It seems that the 2 original bulbs have been damaged in the boot since being replaced so a new bulb is needed :roll:
Now how silly do I feel hahaha :o:
Thanks as always guys :cool:
leeparkes
Post Sun Nov 06, 2011 11:07 pm
It happens to the best of us. :D
e30-EVN
Post Sun Nov 06, 2011 11:09 pm
Yep, but this time it happened to me!! Hahahaaa :D
Sanchez
Post Mon Nov 07, 2011 6:38 pm
Well at least its all working now.
'E30Zone, more help then the RAC'
