Went for a drive and a light popped up saying dipped beam. Pulled over and checked it, passenger side out!
Replace with a known working bulb and still not working! I've just checked the fuses and they are all ok.
What is the problem guys? Can anyone help?
T I A
headlight out, its not the obvious.... pls help
e30-EVN
e30-EVN
Anyone?
By the time I get home from work it will be dark tomoro night so I need to fix this
- E30 Zone Meets/Events Team
Sure the bulb you replaced is a good one??
I've done this too , and replaced with what i thought was a good working bulb, then went through checking fuses etc....., turned out the replacement was fooked too.
Try another bulb.
Try another bulb.
Sanchez
put the bulb from the working light into the non working light to see if it is the bulb.
If it still doesnt work go though the wiring.
e30-EVN
Well what happened was my old bulbs were working fine but as you know they give off a yellowy light so I went out and bought ice white bulbs which I put in and all was good until tonight....
Then I put 1 of my old bulbs straight in but no joy! Its been in the boot in the box the new 1's came in but I guess it could have rolled around and damaged..?...
I will try now
Thank you
I will try now
Thank you
e30-EVN
Guess what boys......... Lol
Put drivers side bulb in and hey presto!
It seems that the 2 original bulbs have been damaged in the boot since being replaced so a new bulb is needed
Now how silly do I feel hahaha
Thanks as always guys
leeparkes
It happens to the best of us.
e30-EVN
Yep, but this time it happened to me!! Hahahaaa
Sanchez
Well at least its all working now.
'E30Zone, more help then the RAC'
