A) chop the bmw flanges off the bottom, get some slightly oversize pipe bent to shape, run these down to a standard 325 exhaust starting point, weld the bmw flanges back on, then buy a stainless 325 exhaust and go from there
B) as above but dont weld the bmw flanges back on and use a friction fit the same as off the manifolds in A
C) take the manifolds off, chop the bottom part of them up and fully fabricate the manifold to finish up where the 325 exhaust would start, then buy a 325 stainless exhaust
D) Do none of the above, take it to an exhaust fabricator and get them to do it
E) run straight pipes
does any one know of an off the shelf exhaust for an e30 that has pipe dia of 50mm? (2")
cheers lads
