Gaz Coilover Fitment - Anyone Had These Issues?
f0xy
Post Mon Oct 31, 2011 12:09 pm
Fitted a set of Gaz Golds to my E30 a couple of days ago but hit some quite major issues - thought I would post up to see if anyone has had anything similar in the past. Before fitting the car had -
- New Standard Top Mounts
- New Front Hubs/Bearings
- New Wishbones + Bushes
- Standard Front Discs
- Standard 15" Wheels
I fitted the standard discs for testing purposes (as I am going to be fitting a WMS set in the near future), then bolted up the standard 15" wheels which I will be using. These are fitted with the standard size 205/50/15 tyres. The wheels had budgets on which highlighted this issue, and I've since fitted some 205/50/15 Michelin Pilot Sport Cups which are the same dimensions anyway.
The tyre rubs on the coilover like its too close to the hub, the wheel physically does not turn. I fitted 10mm spacers to one side to see what difference it made, it did improve it but the tyre still touches - which is completely pointless as I didn't want to run spacers anyway. As you can see from the pics below..
10mm Spacer Fitted:
No Spacer:
Few Other Pics:
As you can see the car is at a reasonable hight, coilover adjuster is set halfway so not stupidly low..
Has anyone experienced similar issues with Gaz coilovers?
Are 318iS and 325i front hubs/stubs different (part with the bearing)..
Im currently in the middle of contacting the supplier/Gaz anyway, but thought I would post up to see!
Cheers.
keri-WMS
Post Mon Oct 31, 2011 2:10 pm
If it helps to rule out the hub and wheel bearing, the hub face > caliper lug mount face offset reference dimension I use is 50.40mm (I suspect BMW were aiming at 50.00 but I base the dimensions I use on real life struts).
Hope that helps!
One very unlikely possibility is they are 325ix (4x4) wheels, doubt it though....
Demlotcrew
Post Mon Oct 31, 2011 2:23 pm
Just get some 20mm spacers on there! :D
Post Mon Oct 31, 2011 2:38 pm
That is a frequent occurance. Spacers required.
It's because the spring platforms sit lower than on the OEM strut.
keri-WMS
Post Mon Oct 31, 2011 2:54 pm
Wouldn't shorter springs help? What's the ID on the springs, 2.25" or 2.5"?
f0xy
Post Mon Oct 31, 2011 3:20 pm
Keri, good point about the offsets. *Could* be from an iX but I doubt it, I got them from a 325 I think. I will check later.
If I knew I would have to run spacers I wouldn't have bothered ordering them - this is purely a track/sprint/hillclimb car and I generally dont like using spacers really. If I knew this was going to be the case I would have machined up some different stubs or similar to give me the clearance.
The other issue I have with spacers is I have purchased the two new front hubs/bearings, milled the threads out to give me a 1/2" hole and done a press stud conversion (65mm studs) like I have with previous cars as I find they are a lot more reliable than bolts, especially when changing wheels a lot.
With that I can only run a maximum of 10mm spacers anyway once the disc and wheel are on, as I reach the end of the stud. Even with 10mm the tyre still rubs. Really with a suspension kit costing as much as it does I shouldn't have to be pi**ing round with spacers, never mind (quite large) 20mm ones just to get a wheel to fit.
I have specifically ordered a 4pot kit from Keri to fit under the standard wheels as I have a number of them with lots of different tyres on, if I would have known the standard wheels wouldn't fit I would have found other wheels in the first place and ordered a bigger brake kit.
Im going to pop one of the front struts off later for a measure, so I will find out the spring length and size then!
Post Mon Oct 31, 2011 3:28 pm
They are cheap coilovers still.. It is just a fact of running coilovers with certain wheels. The spring seat sits lower and can foul. End of.
The other option would be lower offset wheels.
The spring length does not look excessive to me either. Shorter spring will equal less travel, so might not be a valid solution. They look 6" to me. Maybe 5" length with larger coil gaps as KW offer (at a price) would help, though I feel they would still catch.
f0xy
Post Mon Oct 31, 2011 3:53 pm
Yeah I am not saying they aren't 'cheap', but I really couldn't justify (or see the point) in spending the extra to get KW's, or even more for H&R when Gaz are UK based, have good turnaround times and I've had a very good service from them with rebuilds and supply over the past 5 years.
I also wanted complete rear coilover units (regardless of whether the standard strut tops can take it or not as its having a full cage) so I had the option of using a multitude of different spring lengths and rates as I wanted, even more so off the shelf from a number of companies not just Gaz.
Either way Gaz are what I went for, even after research on here I never once saw it mentioned about standard wheels fouling the shocks. Fair enough they are wider/have the spring in a different location but it would have been better if the question was asked upon manufacture or ordering as I already had a large number of the same wheel waiting to be used.
So now im basically being told I've spent £850>, have four sets of wheels with tyres sat around and I have to use spacers that are a minimum of 20mm? Seems a bit of a joke to me considering they are supposed to be 'standard fit' coilovers.
Im pretty sure everyone who has purchased Gaz on here before havent gone out and sourced different wheels at the same time... There has to be some people using the standard 15"s surely, if not in the E30 series?
Il have to have a proper check of the offset and measurements later.
Post Mon Oct 31, 2011 4:02 pm
It is a very common thing to have to run a spacer to clear the wheel. It has been covered before, even on this forum. It's not a question I would deem they should ask. I have never been. Wheel/tyre fitment isn't the responsibility of the manufacturer. Maybe they should insert a "May require spacers to fit" sentence.
It isn't a Gaz thing, it's a coilover thing. The PBMW guys run 195/50 tyres, I am not 100% on spacers or not.
Post Mon Oct 31, 2011 4:03 pm
Post Mon Oct 31, 2011 4:04 pm
That was a search of the word Coilover in Tech section btw..
keri-WMS
Post Mon Oct 31, 2011 5:21 pm
I (personally) would look at doing this - reduce the profile of the platform ring a bit, and reduce the lock ring more while adding holes so you can use a pin spanner. Do your own safety checks etc obviously, but I would be happy with it on my car!
Post Mon Oct 31, 2011 5:22 pm
You aren't going to get 20mm of clearance making a smaller dia collar..
keri-WMS
Post Mon Oct 31, 2011 5:34 pm
No, but with a slightly shorter spring the nearest bit of the tire will be aproaching 45 degrees, so this would let you sit the platform about 10mm lower or the tire a bit closer. Every little counts!
Post Mon Oct 31, 2011 5:37 pm
keri-WMS wrote:No, but with a slightly shorter spring the nearest bit of the tire will be aproaching 45 degrees, so this would let you sit the platform about 10mm lower or the tire a bit closer. Every little counts!
Depends if the lesser travel is an issue..
keri-WMS
Post Mon Oct 31, 2011 5:56 pm
Yep, the travel thing may be a pain, but there are a combination of things that should all help when added up:
- Shorter spring.
- Sit the car slightly higher.
(both raise the platform up the strut)
- Lower profile seat/lock ring.
(gives more tire clearance directly)
None will work on their own, do them all and you MAY be in business without wheel spacers.
Another way to look at the modified rings is that every mm saved here as a mm longer the spring can be, so the reduced profile rings are actually allowing more travel not less.
f0xy
Post Mon Oct 31, 2011 6:01 pm
Very interesting info and lots to think about. Im off to drop the car off now and remove the front struts, so I will have a measure.
I could easily draw up and machine new front stubs that were 15mm wider with the hub nut countersunk further in, combined with a custom bearing that has the same ID as the BMW one, to give me the same effect as a spacer. But its besides the point as I would have issues with the brake mountings and disc position in relation to that then.
Its just the only thing I dont like about spacers is its another thing to come loose and another thing bolted in between, especially when you get to the size of 20mm.
Dan320is
Post Mon Oct 31, 2011 6:10 pm
I have to use a 12mm spacer for the tyre to clear the coilover strut. Common practice with running a coilover on an E30.
f0xy
Post Mon Oct 31, 2011 11:21 pm
Checked before, all the wheels I have are ET24, so not iX wheels. Not had chance to get one of the front struts off either, so I will have to do that tomorrow.
Even if I had a 12mm spacer it would be damn close, 10mm is still touching. I have to consider the Michelin Pilot Sport Cups are bang on 205, with thicker sidewalls than a normal tyre, and the amount they will move/flex/expand with heat being hammered round a track. I would ideally like a nice amount of clearance!
Post Mon Oct 31, 2011 11:52 pm
It isn't a strut thing. You'd notice it if it were. Coilovers require spacers basically, as has been said.
Dan can run a smaller spacer as he has lower offset wheels and thinner tyres.
Coops90
Post Tue Nov 01, 2011 5:16 pm
I have FK KonigSports on mine, run standard 15" BBS with 205/55/15s and got away with a 5mm spacer each side.
FKs must have shallower collars perhaps.
Isn't fantastically helpful or relevant but oh well.
Malachite uber alles
f0xy
Post Wed Nov 02, 2011 12:14 am
Yeah I understand its not a strut thing, but it just seems a bit stupid to HAVE to run spacers just to run coilovers. As for the search a few posts earlier, I never saw that thread - I was searching the whole forum for Gaz Coilovers but it was returning 100's of results, none at all relevant.
Either way I got some dimensions as Keri mentioned, 50mm from the caliper mount to outer face of the hub is the same also..
Even if I was to run 20mm spacers my studs are not long enough (longest I can get hold of), as they only have 51mm of available thread.
If I was to get 'bolt on' spacers (potentially another 4 nuts/bolts to work loose) which the wheels would then bolt to, the studs would be too long and stick out the end of the spacer - so basically that's pretty much a pair of brand new front hubs, bearings, machine time and studs wasted as they are useless either way.
Yet another waste of time that I cant believe I didnt know about before ordering any suspension - I would have been even more unimpressed if I had spent KW or H&R money, it just makes no logical sense why 'you should have to run spacers' with standard parts. I think the only way around not running a spacer with coilovers is a caliper spacer and custom hub + bearing setup.
Post Wed Nov 02, 2011 1:38 am
why not ask "Gaz" what you need to do to make them work ?
IMO coilovers = fail
spacers = bigger fail 8O
f0xy
Post Wed Nov 02, 2011 8:17 am
I have done.. No constructive comments back from them yet.
gooner1
Out humping Reindeer
Post Wed Nov 02, 2011 8:41 am
Not exactly constructive from me , foxy, but just in case.
http://www.e30zone.net/modules.php?name ... c&t=208459
MJJ_ZX6RR
Post Wed Nov 02, 2011 9:16 am
F0xy,
I feel your pain, I had the same problems (http://www.e30zone.net/modules.php?name ... highlight=). In the end, it is clear that coilovers were simply the wrong choice for my road car, and the supplier eventually agreed to have them back and fit Bilstein/Eibach for me instead.
Before coming to that choice, we discussed a custom shorter spring to allow the bottom collars to be wound further up, giving clearance.
Overall though, I am with you. If you need to fit spacers, or modify springs to avoid tyre fouling, then these coilovers are shoddily designed items simply not fit for any purpose.
Martin.
Lots of bikes, the odd modern BMW, and now an 88 e30 335i Cab project with E32 running gear
Demlotcrew
Post Wed Nov 02, 2011 9:21 am
All coilovers for the E30 need spacers.
If you are fitting coilovers then you will also benefit from a wider track, just because someone completely messed up their hubs with press studs they are now expecting Gaz to have a magical solution.
Man up, get some new hubs, spacers and some proper studs and finish what you started. I have no sympathy for stupid oversights.
Andrew
Post Wed Nov 02, 2011 9:54 am
MJJ_ZX6RR wrote:Overall though, I am with you. If you need to fit spacers, or modify springs to avoid tyre fouling, then these coilovers are shoddily designed items simply not fit for any purpose.
Martin.
Wrong. It is down to the nature of a coilover (on an e30), and the lower spring perch. Simple. There are ways and means to lessen the effect, but it is a fact of coilovers.
You don't have to fit spacers, you could run lower offset wheels..
MJJ_ZX6RR
Post Wed Nov 02, 2011 11:11 am
Jhonno wrote:Wrong. It is down to the nature of a coilover (on an e30), and the lower spring perch. Simple.
I am interested to understand this more, I am not experienced in the suspension world. What is it about the inherent design of a coilover over a separate spring/damper setup? Longer spring?
If coilovers need such mods to make them fit, I am really struggling to understand the point of them over a separate spring/damper setup.
Martin.
Post Wed Nov 02, 2011 11:25 am
With a standard strut, the spring seat is fixed. To lower the car you shorten the spring. The spring seat sits above the wheel.
With a coilover, the spring seat is adjustable. To lower the car you lower the spring seat. Which is where the issue occurs. You lower it into the space the wheel occupies.
Coilovers are designed to be adjustable to set rideheights, and corner weight. Also ease of replacing springs.
Mikey_Boy
Post Wed Nov 02, 2011 12:12 pm
You could fit bigger wheels - I run 17s (ET25) with my Gaz coilovers - no clearance issues for me - it is tight mind! winkeye
f0xy
Post Wed Nov 02, 2011 5:18 pm
Demlotcrew wrote:All coilovers for the E30 need spacers.
Andrew
Im not asking for sympathy from anyone, nor am I expecting Gaz to have some 'magical solution'. I was just querying why spacers have to be used, and how stupid it is.
The hubs are far from 'messed up', press studs are FAR more reliable than any other type, if you believe otherwise then you clearly have never used the car hard enough/on track to know otherwise.
At pretty much every track day/sprint/hillclimb I go to someone always has a failure with shoddy screw in studs, whether it be them unwinding with the nut stuck on them or just coming loose completely.
So I wouldn't call them messed up, they are perfectly usable, just not with the suspension setup I am now using as it seems. They would be perfectly reliable all the way up to the bearing failing/becoming worn and then needing to replace the whole unit.
Having to replace the whole unit/bearing in one go is another reason to just draw up and machine my own stub with replaceable bearing with the face 20mm further out and a spacer on the caliper - to have the same effect as a spacer. Everything is just leaning towards that if I dont want to have some sort of 'bolt on' spacer kit.
Demlotcrew
Post Wed Nov 02, 2011 7:32 pm
Its very simple, people who use shoddy screw in studs will have problems. Shoddy studs are cheap and its guaranteed more people will use them over some that are not only better and RELIABLE are more expensive and as a result you will always see a disproportionate number of failed studs at events as they cheap and just about do the job.
I know of many cars running screw in studs, no issues at all. In fact they are much much safer as they convert to a fine pitch thread (4X rotation) You don't get that with your setup.
Your hubs are no use to anyone now, anyone needing more clearance wont be able to use them and anyone not needing clearance will most likely not need studs, so in my eyes that makes them messed up. :eek: + How do you know you have left enough of a margin around the bolt it self, not only have you milled quite a lot of metal from around the original hole, you have also pressed fitted interference ridged (what looks like Ford) studs. I wouldn't be surprised if they cracked the hub with the added pressure and with heat expansion under extreme use, that does not look like a better solution to me.
Anyway i digress, 20mm (you will get away with 15mm) extra track each side will do your car wonders in the handling dept 8)
Andrew
f0xy
Post Wed Nov 02, 2011 10:08 pm
I don't want my hubs to be of any use to anyone.... If I had kept the standard shock (setup) I would have been fine with them and it wouldn't be an issue. Fair enough two hubs wasted, oh well life goes on...
The holes were only milled out to remove the thread, to 12.6mm, so not a lot at all really. Either way there is a lot more material left on than my previous car which ran the same setup on the front hubs and was used for two years on slicks (+180hp/800kg/FWD) without a single issue. They are M12 Ford studs yes. I would have been more worried about the hub cracking in the past with lesser material, but its got more, not to mention the hub face itself being double the thickness of the previous setup.
Yep I have no doubt a wider front track will improve things, as I ran a near 30mm wider track on both sides (front) on the last car, but it wasn't done with spacers. I replaced the whole hub/arm/ARB setup from a newer model, and it was great doing 2.00min laps round Oulton and various other circuits. I will be surprised if the BMW comes anywhere near that even on the slicks again, but I didn't buy/build it for that - I just wanted to change from FWD to RWD.
The point I'm trying to make is I just don't like the idea of large spacers. 5mm or 7mm ones I could deal with, but when you get up to 20mm and you've got twice the nuts/bolts holding the most vital part of a car on doing 120mph+ corner speeds, its always in the back of your mind :)
Demlotcrew
Post Wed Nov 02, 2011 10:37 pm
The BMW BTCC car runs 20mm with only studs, these cars see way more stress than anyone of us could get from our cars.
I seriously would not worry about it.
Andrew
