which pins to reset service lights?
rix313
Post Mon Oct 31, 2011 8:05 pm
Just a quick one, which pins do I need to join in the diagnostic plug to reset the service light?
threelander
Post Mon Oct 31, 2011 8:15 pm
12 and 15 if i remember correctly
torquey
Post Mon Oct 31, 2011 8:35 pm
I think you will find it`s pin 7 to 19,
kolee
Post Mon Oct 31, 2011 8:36 pm
I think its different on the pre and facelift models. Which is yours?
torquey
Post Mon Oct 31, 2011 8:51 pm
it worked on my car it`s a pre facelift , my understanding is any car- post 1987 have a 20 pin connecter so it should be 7 to 19 ground,
Ajsingh
Post Mon Oct 31, 2011 9:20 pm
Ebay. £7 buy the tool.. Will do all bmws from 1982 - 2001!
E30 Crazy!
HairyScreech
Post Tue Nov 01, 2011 11:30 am
its on here a number of times, brian has posted it up quite a lot so it should come up with a search.
mrLEE30
Post Tue Nov 01, 2011 2:31 pm
The reset pin is 7, it needs to be grounded. I personally link 7 and 11 (as 11 is grounded eventually) and requires a two inch piece of wire, same is achieved with a longer piece from 7 to ground such as inlet manifold. This is for ALL e30's, but note prefacelift have the pin numbers inside the cover and are over their pin number when cap is ON. Facelift have pin numbers next to their pins.
Ignition off, ground pin 7, ignition on wait 5-10 seconds, ignition off and repeat to reset oil inspection light and service lights.
mrLEE30
Post Tue Nov 01, 2011 2:43 pm
Just a note to say pin 19 also grounded, but early models only have 15pins, so no 19. 11 is grounded on all models.
e301988325i
Post Tue Nov 01, 2011 6:56 pm
I have pretty pictures of both early and late sockets and which pins reset the lights, I'll E-mail to you if you PM your address.
I said:
e30topless said:
lock the wife in there
