M20 Wiki page - complete?
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Oct 08, 2011 9:32 am
Morning all,
I'm cleaning up the Wiki, and the M20 page is looking a little sparse:
http://www.e30zone.net/e30zonewiki/index.php/M20
If any one of you have some info that you think ought to be there, or can see errors (like hp figures, for example), then say it here and I'll make ammendments
Post Sat Oct 08, 2011 9:47 am
early M20's fitted to e21's were known as the M60 engine back then. They took the M20 name when the e30 apppeared
Grrrmachine
Post Fri Oct 28, 2011 9:51 pm
Well, the M20 page is growing somewhat, but I still need contributions. Parts, faults, niggles, quirks and guides; anything you know.
DmcL
Post Sat Oct 29, 2011 12:10 pm
i can give info on some of the ECU's depending how much into things u intend to go. also think i have an image of the different pistons that cam in various M20's if u wanted to put that up?
WMMotorsports
Grrrmachine
Post Wed Nov 02, 2011 2:33 pm
All the piston info has been added to the Wiki.
Grrrmachine
Post Mon Nov 07, 2011 9:34 pm
The page has finally taken on its proper form. For all you M20 afficiondos, have a read of the content (link in first post) and let me know of any necessary amendments or omissions.
HairyScreech
Post Mon Nov 07, 2011 10:06 pm
i will have a read once uni work is out of the way.
richy187
Post Thu Nov 10, 2011 9:13 pm
Coolant flow is regulated by the thermostat, which is controlled by the ECU based on readings from the temperature sensor.
When the temperature is correct, the ECU opens the thermostat to allow coolant to flow to the radiator.
This I believe is incorrect, The two temperature sensors are for the ECU and temp guage on the dash, the thermostat opens and closes itself according to the coolant temperature, the ECU has no control over the thermostat.
Kedge
Post Fri Nov 11, 2011 4:52 pm
Yea, thermostats have no link to the ECU. Just read up that it's as simple as wax melting that opens the thermostat :o
Instagram - Kedge85
Grrrmachine
Post Fri Nov 11, 2011 8:42 pm
Thanks guys, I've made the relevant adjustments.
HairyScreech
Post Sat Nov 12, 2011 4:41 am
engine is the Sump, a steel dish that provides an oil bath fo
should be aluminium
pretty sure the bearing shells are steel backed white metal rather than just steel.
m21 bearings are copper/lead
with modern semi synthetic oils the oil cooler i not really required
expansion tank on pre facelifts is by the battery
is it open for editing by anyone? if so ill add bits as and when i think of them
eta - the 2.8 stroker page needs some serious updates now as well.
gooner1
Out humping Reindeer
Post Sat Nov 12, 2011 1:55 pm
Kudos to you Grrrmachine. :thumb:
Grrrmachine
Post Sat Nov 12, 2011 10:52 pm
I can give access to anyone who wants it; you just have to ask for a username and password by PMing me (including what you'd like your password to be). You'll then be able to log in and add info. I will only amend your spelling mistakes :D
I've updated the M20 page with the new info. Thanks HairyScreech.
