M30 Turbo conversion
leeparkes
Post Sun May 29, 2011 10:09 pm
Is it an uprated pressure plate too?
staley_turbo
Post Sun Jun 05, 2011 8:37 am
New clutch is in with standard pressure plate. No more slipping. Next is a set of 650cc injectors and a better ratio diff.
One point to make, the duel mass fly weighed 19.4kg complete with clutch assy. The e28 single mass fly weighed 18.6kg complete with clutch assy, This is because of the size and weight of the pressure plate on the single mass. So unless going for a m5 fly, there's no point other than getting rid of the gayness of the duel mass.
leeparkes
Post Sun Jun 05, 2011 7:17 pm
How heavy is your e28 fly on its own? 8O
staley_turbo
Post Sun Jun 05, 2011 7:55 pm
10kg vs the 16kg of the duel mass.
Bristol_Jer
Post Sun Jun 05, 2011 7:58 pm
Is the e28 m535 fly lighter than the normal e28 one? As that is what I have, and the flywheel/clutch combination felt noticeably lighter than the dualmass fly/clutch from my e34 engine.
leeparkes
Post Sun Jun 05, 2011 8:10 pm
Im sure my fly and clutch only weighed in about 12-13kg, although im on an e28 525i fly at 7.5kg so the clutch kit should only weigh about 5kg.
staley_turbo
Post Sun Jun 05, 2011 8:14 pm
My pressure plate alone was nearly 8kg. Standard Sachs
staley_turbo
Post Sat Jul 09, 2011 6:53 pm
New 620cc injectors = Big smile on face.
The car is starting to get really good now, Spent 3 hours live mapping last night, needs about another 8 - 10.
Diff has started to whine, probably due to the torque increase, so i have a few little jobs to do now. I have just ordered a 3.23 diff and getting Gareth to build it up for me.
Having the gearbox rebuilt at the same time along with the rear beam.
Bristol_Jer
Post Sat Jul 09, 2011 7:49 pm
Nice progress, sounds like it's going to be a beast! :twisted:
rob0r
Post Wed Jul 13, 2011 11:13 am
I've just dug out some photos of when I converted my E32 735i manual from dual to single mass E28 2.5/2.8 flywheel and E28 M535i clutch. I weighed everything and lost 4kg in the process. The clutch was nearly brand new and the total cost including the fly was around £120, so a healthy saving there compared to a new dual mass clutch.
Being rude... how much was the 5 paddle?
staley_turbo
Post Wed Jul 13, 2011 12:44 pm
The 5 paddle clutch kit was about £570
rob0r
Post Thu Jul 14, 2011 12:02 pm
Ouch! I didn't think it would be that much, how much power is it good for?
baptie0
Post Fri Jul 15, 2011 12:34 am
I cant understand the benefit of using an uprated plate with a standard clutch cover :?
staley_turbo
Post Fri Jul 15, 2011 9:58 am
Plenty of benefits, better friction material, and the obvious that it now holds power fine as before it was slipping as soon as the boost came in. This will be fine untill the power starts getting to around 450+
Keeping the standerd pressure plate also keeps the clutch 'light' and is better for road drivability.
staley_turbo
Post Wed Aug 03, 2011 7:01 pm
Thought id put a few pics up of her now shes been on the road over 2 months!
This is just after I fitted the new gearbox.
Running 10psi for now and its holding nicely. Fitted the oil catch tank and a few other bits.
Pulls like a train at the min so I have good expectations of future power.
Post Wed Aug 03, 2011 7:38 pm
Bloody :cool: !!!!!
lyricalnut02
Post Thu Aug 04, 2011 7:04 pm
that looks very :cool: matt
325i Sport Tech 1 - R.I.P
E30 addict.
leeparkes
Post Thu Aug 04, 2011 10:46 pm
Any more pics of the engine? looks proper lush :cool:
bridgemond
Post Thu Aug 04, 2011 11:14 pm
Looks very :cool:
staley_turbo
Post Tue Aug 30, 2011 6:04 pm
Thanks everyone. I have now took the car off the road for a month, I feel the engine is slightly overpowering the cars handling so some improvements need to be made. New shocks are a must aswell as a rear beam build. Also throwing the 3.07 diff in.
Im turning to boost up to 12psi to see how it handles it. I will also try and get it on the rollers to get a figure.
Ill get some more pics up as im doing the work.
staley_turbo
Post Sun Oct 02, 2011 5:41 pm
Right, the car is finally back on the road! After a good deal of rear end work on the car.
I had everything powder coated and have fitted powerflex arbs, beam, trailing arm and diff bushes. Febi e46 rear top mounts, wheel bearings and arb drop links. A very clean fuel tank to replace my holy one. New fuel lines, breather lines, and filter. And to finish it off some bilstien b8's.
I also put a 3.15 diff in there thats made all the difference. Car feels tight. But i have had some probs already. Not happy with the diff bush, looks like it has sagged. Also broke a rear top mount today driving over a small drain :cry: so im looking at the rouge engineering ones :D
staley_turbo
Post Thu Oct 06, 2011 3:16 pm
Some new engine mounts :cool:
staley_turbo
Post Tue Oct 18, 2011 12:22 pm
New tial wastegate,
and a new turbo on the way as mines fooked!
I have fitted the engine mounts - what a massive difference. Also had a new exhaust fitted the old one was to loud. After the wastegate and turbo are fitted ill have the map checked the get it on the rollers! :D
Post Tue Oct 18, 2011 1:33 pm
:cool: , how come the turbo's fooked??
staley_turbo
Post Tue Oct 18, 2011 3:19 pm
Play in the shaft, ive not been looking after it properly. :(
staley_turbo
Post Fri Oct 28, 2011 7:54 pm
Got a few good things done today, a much needed, new turbo oil feed. Along with a new turbo and oil/filter change.
Spot the broken one!
All done, abit tidyer.
leeparkes
Post Fri Oct 28, 2011 9:18 pm
Dont know if ive said it before but that engine bay looks proper :cool:
Whats all the black stuff on the turbo on the right? isnt that where air gets sucked in. 8O
lyricalnut02
Post Fri Oct 28, 2011 9:24 pm
looking good matt
E30 addict.
staley_turbo
Post Fri Oct 28, 2011 9:40 pm
Thats oil from where the seal has gone due to shaft play. Its been getting worse for the past few days.
looking good matt
Cheers m8, how is the old girl?
lyricalnut02
Post Sat Oct 29, 2011 3:40 pm
looking good matt
shes doing good mate, hasnt missed a beat since ive had her, getting ready for a complete strip down in the winter for further inspection, fingers crossed i dont find any nasty surprises.
E30 addict.
rob0r
Post Wed Nov 02, 2011 12:51 pm
Simply fantastic! My M30 pulls hard enough, I cannot imagine what your's is like. Great attention to detail 8)
tomislav
Post Sat Dec 03, 2011 9:49 pm
So come on then staley_turbo, any news on your mental engined beasty?
staley_turbo
Post Sat Dec 03, 2011 10:34 pm
Update soon. :D
staley_turbo
Post Mon Dec 12, 2011 8:14 am
Ive been busy making a 3" down pipe. Hopefully let it flow a bit free-er.
leeparkes
Post Mon Dec 12, 2011 4:57 pm
That looks much better. :cool:
Do you know how much power its got?
