1994 318i Touring - Time to Sell :(
Post Fri Oct 07, 2011 12:04 pm
Big difference and there cheap enough in small sizes.
Post Sun Oct 09, 2011 10:29 pm
Might have to get some blitz, need to find a shitty set of bottletops or steelies.
sorted a valance out with 320touring (neil??) once thats on with the new back door the jigsaw is complete.
Spoke to a mate of my cousin and got a respray quote i cannot refuse.
£500 for a full respray :eek: :mad: :mad:
ive had 3 quotes one £2000 one £1600 and one £800 this is the winner, the guy uses his mates bodyshop and does it as a bit of a hobby in his spare time. he use to do it full time but has a better job now
Apparantly his work is excellent too
Result, Expect to send the car off for paint very soon. starting to get very excited he is coming to inspect in this week :D :D
Post Mon Oct 24, 2011 3:44 pm
The car is now officially mine, its also has not been registerd as a Cat C and ive got the log book without it needing a vic check RESULT :D
Car was written off last december, HPI/car check still shows as clear and not as a cat C write off
Had to sell the original IS lip as i was tight for money but now i got a brand new one ready to go one
nice new exhaust trim and some new grill clips
ive also got a heckblende on the way, need to think of a way to fill the lock cutout but might not be noticable when fitted.
Car is off for paint on the 11th Novemeber should get it back the following Monday/Tuesday :D
Post Mon Oct 24, 2011 3:48 pm
Nice one Alex - can't be that may E30's out there than only have 1 previous owner 8)
So if/when you sell it in the future a HPi check will come back clear ?
MurphyE30
great news Alex :D
coming together nicely now :thumb:
any luck with the front seats yet mate?
Jim320i
E30 Zone News / COTM Team
Post Mon Oct 24, 2011 3:49 pm
How much was the Heckblende? I have seen these sell for stupid money before :mad:
i dont know but the dvla have had nearly a year to put it on and its still clear so.....
I still cant belive its clear, i might do another check but dvla say it doesnt need a VIC test and Hpi says clear. :mad:
Post Mon Oct 24, 2011 3:50 pm
Jim320i wrote:How much was the Heckblende? I have seen these sell for stupid money before :mad:
£50 posted from germany :D
Has a crack in the reflective bit but its behind number plate so you cant see it. they certainly do sell for daft money :mad:
Not yet :cry:
MurphyE30
Post Mon Oct 24, 2011 10:25 pm
Not yet :cry:
I would seriously consider sourcing a set from German ebay mate. i know the shipping ect.. might be abit more hassle but they come up on there
Post Tue Oct 25, 2011 11:22 am
MurphyE30 wrote:
Not yet :cry:
i wish i had got the purple one as there is loads of purples seats but no neon green ones on ebay.de :(
320Touring
Post Tue Oct 25, 2011 12:31 pm
Hurrah!
Glad to see this is taking shape!
Top work, young un!
MurphyE30
Post Tue Oct 25, 2011 4:25 pm
Alex wrote:
MurphyE30 wrote:
Not yet :cry:
Be patient dude a set will come up in time :) just keep an eye out
So is the 20th the date for being back on the road then?
Post Tue Oct 25, 2011 10:51 pm
Going to get it ready for MOT tomorrow, and possibly get it MOT'd before paint so i dont have to clart about fannying on with getting it transported etc.
Post Wed Oct 26, 2011 6:38 pm
Nearly ready for MOT, going to tax it soon now i have log book, ive managed to fix my broken indicators, the wing indicator pins in the socket had come out and were touching shorting the circuit out.
I also fitted the new tie rod end, what a B@stard that was too do, the thing kept spinning when tightening and undoing the nut :cry:
for MOT i need to fit my washers, Fit an indicator bulb and fit new brake light switch and i'am confident it should pass :D
managed to get the front end all together today, going to order some new black trim that goes round the bumper i think, and will get some dealer plates made up.
i also tried knocking the dent out the back door, the larger one popped out but the bottom was too creased / dented so need to swop all the internals into a new door which i have, bit of a pain in the arse, why do people remove absolutly everything when you buy a door :roll:
I'am hoping to get it mot'd before paint that way i dont need to fanny on getting it transported to the paint shop
still along way once the outside is done i can get stuck in with the interior
goodbye crap door
1 indicator bulb needed, removed all the fogs etc to make it easier to paint
Kedge
Post Thu Oct 27, 2011 1:28 am
Getting there :cool:
Don't envy you with the door, i have taking things out of them, would want to avoid putting stuff back in at all costs.
Instagram - Kedge85
Post Thu Oct 27, 2011 7:28 am
I've got to swap the drivers door on my Touring - been putting it off for months because of all the internals needing to be swapped over :banghead:
darkchild
Post Thu Oct 27, 2011 8:07 am
Good work Alex. Looking forward to seeing this finished.
Post Thu Oct 27, 2011 1:37 pm
is it booked in for an mot yet :D
Post Thu Oct 27, 2011 3:05 pm
Coming along Alex.. I had a properly quiet M40 in my old turd.. It had 50k on the clock when I got it, FBMWSH, used to go well! :)
Dezzy
CR24v it's a lifestyle
Post Thu Oct 27, 2011 5:12 pm
MOT'd yet??
hennared323i
Post Thu Oct 27, 2011 8:26 pm
capri_rob wrote:I've got to swap the drivers door on my Touring - been putting it off for months because of all the internals needing to be swapped over :banghead:
Easy,
Take door off leaving body supports bolted in place - open door, unclip barsteward stop clips and remove pin - open wider (but not to wide), undo nuts on hinge pins and lift off (tricky with wing on but can be done)
Lay it on its back on suitable supports
Remove trim/gubbins as required
Fit new gubbins/trim as required - you will not find a simpler way to replace lock barrels
Re hang new door - do up nuts, clips etc
Then spend ages shimming and lining up - :D
I'm liking the work here Alex, good luck with the MOT
Post Thu Oct 27, 2011 10:56 pm
Dezzy wrote:MOT'd yet??
No going to book it in for a week tomorrow, need to get a few odds and sods, then i can bring it home tinker with it for a week, then its off for paint on the 11th Novemeber :D
service kit arrived today, ideally want to do cambelt soon but might just pay someone to do it :mad:
i also treat myself to one of these this morning. :D :D
Post Mon Oct 31, 2011 10:33 pm
All finished and working as it should, all little odds and sods done.
Swopped all the internals into the new door took a good hour and a half :x :x
old door, looks perfect in the picture but the lower half is crippled to death :(
new one, wrong colour like the rest of the panels, however to save cost ive said to the painter it wont need painting both sides like the rest of the panels, he was happy with that.
plenty of waxoil
after pumping the tires up with a crappy £3.99 footpump i pulled the car out and fitted the back door. all panels arnt lined up 100% but bodyshop will do all that for me. they all close as they should and arnt too bad.
wanted to take some before pictures of the crappy areas.
Just a case of driving it down to the mot garage now, day off on friday so fingers crossed. its only done 2000 miles since last mot and no advisorys were given. :D
Getting a little excited now, cant wait to be driving a proper bmw again, the compact is shite.
Post Tue Nov 01, 2011 4:03 pm
Nice work Alex - fingers crossed for a straight pass with no advisories :D
Post Tue Nov 01, 2011 6:33 pm
Cheers, tried taxing it tonight seems i need to have it on the insurance register and have an MOT on it :roll:
Post Tue Nov 01, 2011 6:36 pm
no mot or insurance = no tax
best of luck on friday m8,it should p1ss it
Dezzy
Post Tue Nov 01, 2011 10:23 pm
Good work mate.
I hope the painter isnt that cheap for a reason?
Fingers crossed for Friday, Im sure you won't have miss out 8)
Post Tue Nov 01, 2011 10:37 pm
the painter doesnt make much money from it, he said its more of a hobby now. he had a partnership with a guy with there own bodyshop but ended up leaving for a better job at cummins, however he still takes on work and uses his weekends to do it, his work is excellent so i'am told. he is painting everything from windows down and going to buffer the roof up with g3 etc. he is also going to take a dent out of drivers wing and try and make the rear valance as straight as poss.
its costing him £100 to use the bodyshop, originally was £50 however his mate has that much work on he was a little reluctant. then i'am guessing £200-£300 for paint and the other £200-£300 is his for a weekends work. he knew a fair bit about e30s when he seen it, he was telling me to fit a tech II kit
total price is £550
Come to the meet on the 20th and see what you think. :D
Dezzy
Post Tue Nov 01, 2011 11:06 pm
I'll see what im up too mate.
I'd like to give it the once over :cool:
Post Wed Nov 02, 2011 9:44 am
the too front tyres are shagged anyway, there legal but cracked and loose pressure, so i'am sure i will be up for some new boots :D
Dezzy
Post Wed Nov 02, 2011 10:05 am
Alex wrote:the too front tyres are shagged anyway, there legal but cracked and loose pressure, so i'am sure i will be up for some new boots :D
Sounds good
Post Fri Nov 04, 2011 10:09 am
Mot in 2 hours, my brake light switch still hasnt arrived my local motor factors is getting me one in an hour then ive got an hour to jump start it fit brake light switch and get it to garage by twelve :cry:
All insured now too, i'am a bit nervous hope it passes and this brake light switch arrives in time :cry:
hope i dont get pulled too, its got pull me all over lol
:mad:
Post Fri Nov 04, 2011 11:14 am
Alex wrote:Mot in 2 hours, my brake light switch still hasnt arrived my local motor factors is getting me one in an hour then ive got an hour to jump start it fit brake light switch and get it to garage by twelve :cry:
:mad:
it's got project in progress all over it.
if you have the old light switch you can secure it with long cable ties if one of the tags has broken off :wink:
nowt like a bit of pressure to keep you awake :D
Post Fri Nov 04, 2011 1:22 pm
Well It Passed Woooooo :rock: mot tester said he has never seen an old car like this as clean underneith
drove sooo much nicer than my compact in everyway, the compact is dreadfull compared toi this.
autobox is a bit lazy, it kept changing gear too early and doenst kick down at 60/55mph. engine is soo quiet. once the car changes gear and goes its deffintly quicker than the compact 8O
anyway its home on the drive, just need some tax now :cry:
the new mot certificates are abit piss poor :roll:
320Touring
Post Fri Nov 04, 2011 1:45 pm
WIN! :D :cool:
Nice one Alex
I may actually have to sort the touring at this rate- Just needs tax but so many niggly bits :cry:
