320i waterpump
jimbob29
Post Wed Oct 26, 2011 1:08 pm
after a rumbling sound from the front of the 320i engine when up to temp turns out that the water pump bearing has failed but no leaks no overheating ect i found out that these are bugger to change.how long will the pump last with a worn bearing and how much would a garage charge to replace?
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Oct 26, 2011 1:20 pm
changing the pump means the timing belt comes off. Considering you can't re-use a timing belt, that's the job you have to price up. Garages will milk that, because although it's only a two hour job for someone with experience, most people are too scared to tackle it myself. Quote is normally a couple of hundred, plus parts.
There's plenty of guides online to doing it yourself.
Sanchez
Post Wed Oct 26, 2011 1:34 pm
Get a metal impellor water pump as well, last longer.
Post Wed Oct 26, 2011 1:59 pm
Timing belt doesn't have to come off, and the pump on a 320 isn't at all difficult to change!
Get stuck in!
Leave the timing belt tensioner spring and guide pin off when you fit the pump, and keep them in a safe place until the next belt change (or just buy new ones when needed).
mrb27
Post Wed Oct 26, 2011 2:48 pm
i did mine a few weeks back, didnt remove the timing belt, easy job imo
Andyboy
Alpina Colada
Post Wed Oct 26, 2011 4:14 pm
Don't think I'd be leaving the spring and pin out - although it won't really make much odds. They can be an absolute bastard to refit. The problem is that the other end of the pin sits against the water pump. The way I do it is this:
With the belt covers off, slacken the long tensioner pillar bolt, and the 13mm lock bolt. Push the tensioner back against the spring about 3mm, tighten the lock bolt. Use a pair of very small locking grips on the end of the pin so that the spring and pin are under compression. Slacken the 13mm lock bolt, push the tensioner wheel back to where it was and retighten. The water pump end of the tensioner pin is now clear of the pump. Replace the water pump, slacken the 13mm lock bolt and release the small grips on the pin - the tensioner will then release, tensioning the belt. Tighten then lock bolt and pillar bolt, job done.
However, if the belt has done upwards of 20'000 miles, it's a good idea to change both the belt and the tensioner early - you're already halfway there.
groovylee
Post Wed Oct 26, 2011 4:51 pm
as andy says above really. i did my first e30 cambelt change on my 1990 cabrio, and the hardest thing was removing the bonnet to make access easier. all in it took me 3 hours for cambelt, waterpump, and tensioner. just follow the guides and you can't go wrong, especially if the belt is staying on, but as said above, if it has already got quite a few miles on it, it would be worth changing it for the sake of a few quid for a belt.
good luck dude :)
mrb27
Post Wed Oct 26, 2011 6:59 pm
when i refitted mine i tilted the pump into place with the pin/spring in place and wiggled it into place, was a bit of a pain but i got there :mad:
Post Wed Oct 26, 2011 8:34 pm
mrb27 wrote:when i refitted mine i tilted the pump into place with the pin/spring in place and wiggled it into place, was a bit of a pain but i got there :mad:
A very good way of tearing the gasket!
Spring and pin have absolutely no purpose, other than when actually fitting a cambelt.
mrb27
Post Wed Oct 26, 2011 9:15 pm
well i didnt tear mine :D skills my friend winkeye
Ajsingh
Post Thu Oct 27, 2011 12:00 am
Really?!
I will keep that in mind as there a bastard to get back
By the way, why dont u give this job a shot? Or are u no good with tools?
E30 Crazy!
