Wheel spacers
oze30
Post Wed Nov 09, 2005 10:58 am
What size spacer will i need if Im putting 17's on the touring. No drop, just standard.
Hyperion
Post Wed Nov 09, 2005 11:57 am
what off set are the 17"s
panesar_e30
Post Thu Nov 10, 2005 10:59 pm
all depends on the offset of the rims and the width. :D
Ziggy
Post Fri Nov 11, 2005 9:56 am
Same answer as you got on your other thread....
http://www.e30zone.co.uk/modules.php?na ... ic&t=21770
oze30
Post Fri Nov 11, 2005 11:51 am
Oops!
Sorry bout the double post!!
Found out its eta 37.. WTF does that mean?
Ziggy
Post Fri Nov 11, 2005 12:01 pm
That's the main thing you needed to know :thumb:
The other things that matter are the width of the rim & the tyre...
Assuming it's a 7inch rim with a 205 tyre on it (like a standard BBS), you'll want to get the offset down to around 20-25.
37 is usually a FWD offset, & they'll sit further into the arches (& hence probably hit the struts) than an et 24 (bbs again) rim.
People often say that 35 is a standard offset for the e30, but (AFAIK!) that's only on the 14 rims, which are narrower, so still clear the struts.
A 10mm spacer will probably be enough (giving et27 overall), but the only way you'll know for sure is to find someone with the same size wheel / tyre who's tried it...
HTH! :)
Dan318-is
Post Fri Nov 11, 2005 12:04 pm
the et is 37
the size is 7jx 17, tyres are 205/45/r17
i had no strut hitting issues on mine without spacers but did feel vibration at 80 an then agian at 120ish
oze30
Post Fri Nov 11, 2005 12:06 pm
Was that MPH or KMH?
