M52 rod bolts, tightening spec?
Post Mon Oct 24, 2011 10:39 pm
Are these like M20 ones where its 20Nm and then 70 degrees?
maggspower
Turbo Farmer Tractor Driver
Post Mon Oct 24, 2011 10:57 pm
I thought that these were the same as m20 ones, but no. They do spread across quite a bit of the range though :mad:
http://www.realoem.com/bmw/partxref.do?part=11247589671
For the 4 cyl e30 using these bolts it says 55nm, and no further angle, according to my bentley book. I would wait for confirmation of this though.
Andyboy
Alpina Colada
Post Mon Oct 24, 2011 11:03 pm
Simon13 wrote:Are these like M20 ones where its 20Nm and then 70 degrees?
According to BMW, 20nm and 70 degrees. Haynes backs this up as well. It's the same on the M40 and M43 4 cyl motors too.
Post Mon Oct 24, 2011 11:10 pm
I hope so i've just done them up on my rebuild like this and then thought poo didn't check this before.....
i can change if its not correct but thought i'd ask the greater collective!
maggspower
Post Mon Oct 24, 2011 11:29 pm
Yep andy is right, check page 28 of the torque tightening sticky in the tech section :)
Andyboy
Alpina Colada
Post Tue Oct 25, 2011 9:07 am
Thought you'd have installed some ARP rightness Si. Nothing wrong with the BMW bolts though.
Post Tue Oct 25, 2011 5:52 pm
An M20 is never going to rev enough to warrant ARP! :D
Post Tue Oct 25, 2011 7:57 pm
Now this is true!
