okay this should be an easy one!
ive got the z3 shifter to go into my e30 m52.
in order to put the ball joint of the lever into the plastic socket do i just press the lever in from the top side?
orrrrrrrrr does the ball go into the socket beforehand and then both parts go into the metal housing?
The only reason i ask is the plastic socket is brand new so im very paranoid about breaking it! (i dont want to wait for a new one!)
cheers,
Matt
gear leaver replacement
randomspeedfreak
bimanut
I`m pretty sure you put the lever into the palstic socket then put the socket into the cradel and then turn the socket to lock it in place
randomspeedfreak
ok cheers matebimanut wrote:I`m pretty sure you put the lever into the palstic socket then put the socket into the cradel and then turn the socket to lock it in place
Correct - IIRC when I did mine i used a pair of long nose pliers to turn the socket until the lugs clicked into place - it is quite stiff too turn so be patientbimanut wrote:I`m pretty sure you put the lever into the palstic socket then put the socket into the cradel and then turn the socket to lock it in place
