Has anybody tried this?
http://www.evanscooling.net/www.evansco ... fo.php?p=2
Saw them at the Autosport show a couple of years ago
Any alternatives?
Thoughts invited
Andy
NO!Barx325i wrote:water is surely perfectly ok.....
come on malc, next thing you'll be telling me that all convertbles and tourings had rear discs and 51mm struts, and that bears defecate in the woods. In response to the TOPIC I used the word 'water' in contrast to 'water-less'daimlerman wrote:NO!Barx325i wrote:water is surely perfectly ok.....
you must use a coolant/water mix....all E30's have alloy heads that WILL be corroded by using neat tap water.
True, but plain water has a lower boiling point, increasing the risk of local boiling at hot spots in the head.DanThe wrote:You get better cooling with just water rather than water/coolant, not that its advisable
This is why I am suprised at people using a 50/50 mix!Brianmoooore wrote:True, but plain water has a lower boiling point, increasing the risk of local boiling at hot spots in the head.DanThe wrote:You get better cooling with just water rather than water/coolant, not that its advisable
