Locked out of car with keys inside. Help how to open, please
d1mmy
Boost Junkie
Post Sat Oct 15, 2011 12:56 pm
Any one offer advice on how to open the car door with out a key.
I have both set of keys in the car and the battery was charging. Then the little one closed the door!!!
Any way got the bonnet open tried powering fuse 27 (hope it was the right one)no joy.
Any other ideas, please.
For sale 325i Sport Turbo & 318i (Sport) M50B25
Post Sat Oct 15, 2011 1:06 pm
take the plastic locking trim out of the rear screen rubber then remove the rear window and in ya go.
you can pop the rear screen back in easily but the locking strip may have to be done by a garage cheaply.
**BANNED**
Post Sat Oct 15, 2011 1:25 pm
magpie wrote:take the plastic locking trim out of the rear screen rubber then remove the rear window and in ya go.
Or the same with the windscreen...five minutes out,40 back is my record! :D
Youth is wasted on the young.
tha881
Post Sat Oct 15, 2011 1:42 pm
You can use that blue or yellow strap/tape that is normally used to wrap newspapers or pallets of bricks. Fold it, then push through the drivers door seam where it meets the pillar. Then you can just about wrap it around the door lock pin and lift. You must fold it first though so you have a loop to wrap round the pin once its inside the car.
jimbom30cab
Tech 1 freak
just out of interest, when you put the screen back in, did you use any sealant (like bathroom sealant) to ensure no water leaks??
thanks
**BANNED**
Post Sat Oct 15, 2011 1:49 pm
jimboe39540i wrote:just out of interest, when you put the screen back in, did you use any sealant (like bathroom sealant) to ensure no water leaks??
thanks
No,I have never needed it,but first remove the seal from the car frame and clean all three grooves.Check the car frame in the lower corners,I have found tape covering drain holes,trim the tape back clear of the drain holes.
Fit the seal to the car,then re-fit the 'screen,make sure that it is central to the seal,or the locking strip will refuse to enter the corners.
If you find corrosion in the corners of the frame,you will need to sort that out before re-fitting,or bodge with sealant....
Post Sat Oct 15, 2011 2:00 pm
a spring loaded centre punch is also good for opening windows but a bit messy :D
**BANNED**
Post Sat Oct 15, 2011 2:02 pm
magpie wrote:a spring loaded centre punch is also good for opening windows but a bit messy :D
Automatic nail gun works as well,so I am told,no personal experience,of course... :D
tha881 wrote:You can use that blue or yellow strap/tape that is normally used to wrap newspapers or pallets of bricks. Fold it, then push through the drivers door seam where it meets the pillar. Then you can just about wrap it around the door lock pin and lift. You must fold it first though so you have a loop to wrap round the pin once its inside the car.
The mushroom headed lock pins on E30s make this a very easy operation. Probably why later models aren't mushroom headed.
Don't attempt to remove the rear screen - you will rip off the demister connections.
Topblag
Post Sat Oct 15, 2011 2:06 pm
I used to have one of them.....
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Post Sat Oct 15, 2011 2:15 pm
ford digital radio cassettes were once a premium :D
Topblag
Post Sat Oct 15, 2011 2:17 pm
So were Cossies winkeye
Post Sat Oct 15, 2011 2:21 pm
Brianmoooore wrote:[
after removing about 20 rear screens this way i've yet to break one demisting connector off.
oh look there's a handy piece of that blue or yellow strap/tape that is normally used to wrap newspapers or pallets of bricks
in my glove box,just need to remove the rear screen first to get it ,
:snigger:
d1mmy
Boost Junkie
Post Sat Oct 15, 2011 3:00 pm
Thanks for the tips . How ever i have no idea how to remove a windscreen or put it back in.
Worse case senerio us the trusted hammer - i'll wait till monday for some more inspiration.
Also no more ideas on how to break the glass, i am sure i can work that out. winkeye
Is there any way to trigger the central locking?
Post Sat Oct 15, 2011 3:04 pm
D1MYY wrote:Thanks for the tips . How ever i have no idea how to remove a windscreen or put it back in.
use the key .
:mrgreen:
oomz1975
Post Sat Oct 15, 2011 4:09 pm
Old skool, had to do this many times, back in the days when the battery went flat & the central locking only worked from the boot on my first e30.
murran
Post Sat Oct 15, 2011 4:11 pm
get a length of brake pipe and thread a bike gear cable thru it and solder the end of the brake cable to the brake pipe so theres a loop on the end.
bar the top of the door open so you can get the brake pipe down. get the loop around the lock knob pull on the cable to tighten the loop around it and pull on the brake pipe. sorted.
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
Kos
Post Sat Oct 15, 2011 4:13 pm
hazd31
Post Sat Oct 15, 2011 4:14 pm
windscreen is what i did last time, just be gentle! and at least if it does go wrong your insurance should cover it!
**BANNED**
Using a small screwdriver,lift out the metal cover over the locking strip,centre lower on the 'screen rubber.
Pull out the rubber locking strip.
Go all round the outside of the 'screen,lifting the rubber off the glass(it tends to stick over time,so break the seal)
This next bit is the difficult bit....from the inside,push the 'screen out of the rubber....you are going to have to peel the rubber back at a top corner and attempt to lift the 'screen out of the seal.Use only your fingers,do not attempt to lever the 'screen with a tool.I guess that a 'sucker' on the glass will be a great help,but it should be do-able by fingers only.
Going back is typical Haynes manual,but do take great care to get the 'screen central on the bottom of the seal,otherwise the locking strip will not fit around the corners.Use only soft soap to lubricate the locking strip and lever the locking strip into place with a small screwdriver from the glass side only,then any slips will not leave scars in your paintwork.
Post Sat Oct 15, 2011 4:19 pm
Kos wrote:Image
London !
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Oct 15, 2011 4:20 pm
You guys make it all so complicated.
This is why half of Germany's cars are in Poland...
Post Sat Oct 15, 2011 4:31 pm
for some one who can't remove a rear window i doubt is able of tying a slip knot,
[youtube][/youtube]
LBC FTW!
