broken e30 325i....help
bonnacab
Post Mon Sep 26, 2011 6:56 pm
I have a broken rocker arm on my M20. i am looking to do the repair myself. i have read the head has to come off,is this so?is it easier to change heads rather than stripping one to make good......thanks.
leeparkes
Post Tue Sep 27, 2011 12:19 am
Which rocker broke?
If its near number 6 cyl its easier to change as the rail slides out only a bit to swap the rocker. If its on number 1 cyl the rail has to be slid right out and other rockers removed to get to it.
BUT if you have a broken rocker you will be very lucky not to have a bent valve to go with it.
VW-will
Post Tue Sep 27, 2011 3:03 am
I have m20 rockers if you need them, let me know...
n1tr0_9
Post Mon Oct 10, 2011 6:09 pm
I have a good 325i head if you need one. Also have a 320i head too.
jimbom30cab
Tech 1 freak
Post Mon Oct 10, 2011 6:13 pm
yer, changing the head for a good one sounds best bet to me, plus the added benefit of having a nice new head gasket. The zone is great for this stuff, it wasn't that long ago when a replacement head would have cost mega bucks. :)
bonnacab
Post Tue Oct 11, 2011 9:40 am
have decided to change head as number 4 rocker broke.on inspection yes the valve was bent,the whole head was a bit shot really.got a head off a zoner seems okay apart from 2 exhaust valves not wanting to come out the guide,the tops had mushroomed .can i reuse or are the tops now weakened? should i replace?
mrb27
Post Wed Oct 12, 2011 12:02 am
imo while the head is off if there is anything untoward, replace it! you would hate yourself if you cut a corner while fitting it and something went wrong 2 months later 8O
leeparkes
Post Wed Oct 12, 2011 12:08 am
