Oil Cooler m20
tom325sport
Engine is out the car (M20 - 2.5) I won't be putting the oil cooler back on, what do I do with 2 holes where the 2 oil cooler pipes went near the oil filter?
completely remove the oil cooler housing and fit the stub from the 320i
tom325sport
Yes the oil cooler is already off, sorry what do you mean the by the 'stub'? Thanks
I have been trying to find it on real OEM but can't
, they cost about £4 from the dealers,
it's basically what holds the filter to the M20 block on a 320i they don't use the cooler, and since the cooler housing is prone to leaking then it's the best option to remove it and fit the oil filter direct to the block
tom325sport
OK I see. I'll try and find it on OEM. Thanks
I think it's #5 on here: http://bmwfans.info/parts/catalog/E30/T ... ine_block/
tom325sport
Thanks Brian. So number 5 shown goes into block once the oil cooler housing is removed?
Yes, in place of #6, shown here: http://bmwfans.info/parts/catalog/E30/T ... il_filter/ Oil filter then screws directly on the end.
tom325sport
So just to recap so I don't get it wrong...
Remove oil cooler housing, fit part 5 above, Then oil filter goes on this??
Correct, although I'm not 100% certain it's part #5 on that diagram, since I've only ever done this with the part removed from a scrap B20.
Can't think what #5 would be on the RH side of a M20 block though, if it isn't this.
nickphine
Its a double male adaptor, one end screws in to the block and the other into the standard oil filter, i got mine off a a scrap 320 and it was free because it fitted in my pocket!
