loom help please!
e30mtech
Post Fri Oct 07, 2011 9:35 pm
hi all just started removing engine from my e30, its a 1.6 converted to a 2.5 m20. i am swapping for another better 2.5.
anyway after disconnecting everything ready to remove i noticed the wires at the c101 plug (car end of the loom) was all taped up, upon removing the tape i found this!!!
all wires were connected with blocks and a few cut hanging loose! looking at it i found the brown wire on pin 20 is cut, but i read a page by brian saying that should be done... that correct?
also there was a loose black,
a loose red/yellow
a loose yellow/white
and a loose green/purple although the green/purple has a matching cut wire on the plug!
there was a wire running from the red/yellow to the coil and also the black was the same, think this was to do with dodgy home made alarm system,
also in the pic you can see 2 red wires coming from a block connecting the purple/red wire. the thicker red runs to the ignition cowling, the other goes into the fuse box, ould this be for same dodgy alarm or something else, think the thin one maybe direct to headunit!
bare with me lol
now am i to believe that i can attach the red/yellow to the remains of the brown to make abs work (brian?)
basically to cut a long story short i would like to know what every pin on the c101 plug for and also all wire colours and what they are for ie:
pin 1 - colour - what its for
pin 2 - colour - what its for
etc etc
or a good link with all this info?
so i can do a better neater job
thanks
adam
Mikey_Boy
Post Fri Oct 07, 2011 10:10 pm
Oh jeepers - that really is messy - surprised you haven't had major problems with that!
Anyways - have a look here:
http://www.r3vlimited.com/board/showthread.php?t=202270
Should be helpful...
:thumb:
Mike
e30mtech
Post Fri Oct 07, 2011 10:44 pm
as the shell is a 1.6 i think i need a m40 wiring diagram
looking at that one the green/purple is for fuel pump relay?
my pump constantly runs as you can hear it whenever the ignition is on i take it by connecting the 2 sides of the wire back together should solve this as i'm sure it should turn once to pressurise system then stop?
thanks for info though
Curr946
Post Fri Oct 07, 2011 11:36 pm
mate I personally would put a loom into your car with the look's of things..
you don't need to worry about pin 20 as your car shouldn't have abs with it being a 316i originally.
If your wife must learn to drive, don't stand in her way!
e30mtech
Post Fri Oct 07, 2011 11:40 pm
i have an engine loom but dont fancy doing body loom that be a nightmare wouldnt it!
Curr946
Post Fri Oct 07, 2011 11:45 pm
e30mtech wrote:i have an engine loom but dont fancy doing body loom that be a nightmare wouldnt it!
could be less hassle than trying to find all the bodges in your own loom
e30mtech
Post Fri Oct 07, 2011 11:49 pm
its just under the bonnet that seems to have been attacked pretty clued up with wiring jus need to know what they all are to sort it really, the car ran originally but i like things to be neat and tidy and engine was bit noisy etc so putting another one in
Curr946
Post Fri Oct 07, 2011 11:54 pm
Curr946
Post Fri Oct 07, 2011 11:59 pm
dont do this as if you do youll melt the loom as you will be putting a live to an earth which will end with a messy result and a lot of blue smoke
e30mtech
Post Sat Oct 08, 2011 12:48 am
table is spot on mate cheers
about the brown .... i know this
thought pin 20 was either brown earth or red/yellow for abs?
i have a red/yellow there on body loom surely thats for abs so if my engine loom has a red/yellow on pin 20 i could connect it to the remains of the brown sticking out of pin 20?
e30mtech
Post Sat Oct 08, 2011 12:52 am
also pin 15 black/green - pin 85 unloader relay - what is this for
and pin 8 yellow/white - fuel rate output?
also i seem to have a green/violet in pn 13 for fuel relay not connected but also a red/violet in another pin which is also fuel relay? any ideas?
Post Sat Oct 08, 2011 2:45 pm
This should help with "what wire does what?" Ignore the LH side of the list, which is for an M50.
M50 1/ blue/white (dynamic oil level) E30 2/green/yellow
M50 2/ blue/yellw (static oil level) E30 10/blue
M50 /3 red/white (ABS) E30 20/ red/yellow
M50 4/ black/blue (aircon) E30 not used
M50 5/ black/grey (aircon) E30 not used
M50 6/ purple/grey (aircon) E30 not used
M50 7/ black/purple (drive away) E30 not used
M50 8/ grey (engine check light) E30 12/ grey
M50 9/ NC
M50 10/ NC
M50 11/ brown/yellow (water temp) E30 not used
M50 12/ brown/purple (water temp) E30 4/ brown/purple
M50 13/ green/purple(fuel pump) E30 13/ green/purple
M50 14/ black/white (speed) E30 14/ black/white
M50 15/ black/green ( unloader relays) E30 15/ black/green
M50 16/ white/yellow (Rx data) E30 not used
M50 17/ white purple (Tx data) E30 not used
M50 18/ black/yellow (starter) E30 18/ black/yellow
M50 19/ white/green (service reset) E30 11/ white/green
M50 20/ black (engine speed) E30 9/ black
M50 21/ green (ignition) E30 7 green
M50 22/ green/white E30 6/ green/white
M50 23/ brown/grey (oil pressure) E30 5/ brown/green
M50 24/ white/black (fuel rate) E30 8/ white/black
M50 25/ blue (ignition warning) E30 1/ blue
These are for the engine loom side of the plug. Fuel pump is purple/red in the body loom, as far as fuse 11, then changes back to green/purple.
Plenty of 316i E30s have ABS. If yours has, and has the later version, there should be a red/yellow to pin 20 on both sides of the C101.
Looking at your pic., TBH I can't make head or tail of it, except that to say it's a right mess and in immediate need of attention, which I expect you already know.
There shouldn't be thick red anywhere near the engine loom wiring at the C101 end. The only thick red should come out of the loom at the other end, and connect directly to the battery + terminal, or the smaller terminal in the phantom battery terminal on the bulkhead, if your battery is in the boot.
e30mtech
Post Sat Oct 08, 2011 6:48 pm
hi brian yes i have a yellow red wire there but not connected to the c101 it looks like someone has cut the plug off and changed it for another i am compiling a list of my loom engine side and body side and working out what is missing.
in the pic is body side of plug. as you can see there are remains of a brown so if i just connect the red/yellow it then becomes a red/yellow also my engine loom has red/yellow at in 20 so hey presto abs! and yes it does have abs!
now i also have a black /green a white/yellow and a black not attached to the plug (body side)
from what i can workout correct me if i'm wrong is:
the black/green should be attached to PIN 15
red /yellow to PIN 20
black to PIN 9 as this is tachometer - was originally wired directly to the coil!
now the white\yellow i believe to be for fuel rate/consumption therefor should be going to PIN 16 or 8 any ideas?
can you buy new pin connectors? or remove without breaking?
thanks
e30mtech
Post Sat Oct 08, 2011 8:10 pm
also the red/yellow of the body loom was direct to the positive on the coil???
Post Sat Oct 08, 2011 8:27 pm
E30 C101 colours - body loom side:
1/ blue
2/ blue/black
3/ NC
4/ brown/purple
5/ black/brown
6/ green/yellow
7/ green
8/ yellow/white
9/ black
10/ purple/green
11/ white/blue
12/ NC
13/ purple/red
14/ blue/yellow
15/ black/green
16/ NC
17/ NC
18/ black/yellow
19/ NC
20/ red/yellow
Note that these are the colours I recorded on one particular facelift E30 loom, and some variations may exist with other looms.
New pins and buckets are available. Fitted ones can be removed with the aid of a special tool, which can be bought from the likes of RS components, etc.
In your case, if I understand what has been done to your loom correctly, I'd obtain the short length of loom that comes out from the fusebox, complete with C101 socket, cut leaving a few inches of wire inside the fusebox, from a breaker, unscrew the deck of your fusebox, lift it up, cut the mess you have inside the fusebox and join (solder and heatshrink) all the wires inside.
Post Sat Oct 08, 2011 8:48 pm
Any theories as to why this may have been done?
e30mtech
Post Sat Oct 08, 2011 9:12 pm
spot on brian exactly as i thought.
all i need to do is find out what the 2 red wires spliced in are doing and tidy it all up. the fuse box is all tidy bar that one red wire.
where will i find the buckets and loom?
Post Sat Oct 08, 2011 9:14 pm
Brianmoooore wrote:Any theories as to why this may have been done?
maybe the car is an early pre-C101?
e30mtech
Post Sat Oct 08, 2011 9:15 pm
like i say i think someone has changed the c101 at some point and not went about it properly the whole conversion is a joke hence why i am starting again.
e30mtech
its a 89 facelift 316
Post Sat Oct 08, 2011 9:26 pm
e30mtech wrote: where will i find the buckets and loom?
Use a C101 socket and about 12" of loom from a scrapper.
BMW can supply all the bits new, but good luck identifying the part numbers.
On your car there should be three thickish red wires attached to the battery + terminal, as well as the big black one that goes to the starter motor and alternator.
These should go to the fusebox, the engine loom, and the ABS pump.
The way your car was wired (red/yellow to ignition coil) the entire engine management appears to have been fed from the ignition switch, rather than directly from the battery, via the DME relay.
Why is anybodies guess, but since the car has clearly received the attentions of a complete idiot, then we probably will never know.
e30mtech
Post Sat Oct 08, 2011 10:16 pm
i have a whole new engine loom for my new engine anyway so should work out.
i hope!
if your gonna do job do it right or you'll do it twice!
why people bodge things i dont know, the car did run but idled way high as had wrong icv fitted, i corrected that and it started hunting and cutting out, it had the wrong rad fitted, no header tank, still has 1.6 brakes! etc etc :cry:
so i thought start again do it right! its worth doing as shell is solid plus i enjoy a challenge and a fun project.
e30mtech
Post Sun Oct 09, 2011 9:08 pm
well when it rains it pours!
decided to find out where the large red wire goes and found another mess! a silly alarm system extremely crudly wired in in the dash, it had wires attached to all sorts of areas of the internal loom with insulating tape. i removed a large length from under the bonnet going from alarm siren to inside. and a lot more other areas. almost finished removing all the junk.
now i found that the red wire is attached to a green/grey wire coming from the igniton barrel. brian what is the function of the green/grey please winkeye
i notice there are an extra 2 reds also connected to the red coming from the ignition barrel. 1 is for the dodgy alarm system still to trace the other 1
also the other red running into the fuse box goes into a connector that has 4 different coloured wires which apear to go there as a blank, but the red joins to the green/black on this block which from what i can see runs to fuse 18.
again please brian winkeye what is fuse 18 for? i think it is something to do with the unloader relay since the correct wire for this is not attached to the c101??
Post Sun Oct 09, 2011 10:13 pm
I've seen some hacked about E30 wiring, and I thought I'd seen it about as bad as it gets, but this takes it to a whole new level!
The grey/green on the ignition switch is connected to the grey/brown, also on the ignition switch, when the key is in the off position. IIRC, it's something to do with the E30's parking light function on the indicator stalk. Certainly shouldn't be connected to any thick red.
Fuse 18 is for the higher speed of the auxiliary electric radiator fan fitted along with aircon. Nothing to do with the unloader relays and the green/black!
I'm beginning to think that these thick red wires aren't the OE wiring at all, but have been added in. In the OE wiring all red wires are connected permanently to battery live, without going through any fuse (except in the case of the engine loom red in a car with a rear mounted battery, where it is fed by the fusible link near the battery.)
Apart from the reds I mentioned in an earlier post, the only other ones should be the wire from B+ on the alternator to the starter motor, and one which comes out of the fusebox, appears behind the glovebox area, goes across the car to a plug and socket which should be clipped to a bracket half way down the steering column, and then goes up to the ignition switch as the feed.
Wires out of the ignition switch are a purple, which should be live in positions 1,2 and 3, a green which should be live in 2 and 3, and a black, which should only be live in position 3.
e30mtech
Post Sun Oct 09, 2011 10:24 pm
sorry thought i had said. the red wires are nastily grafted in by a 4 year old auto electrician. they not factory fitted my apologies
e30mtech
Post Sun Oct 09, 2011 10:32 pm
so any idea why someone would join a wire (the thick red) from they grey/green on the ignition to the violet/red at the body c101?
also why also a wire (thin red) from the fuse box (i believe from a wire green/black going to fuse 18) also to the violet/red? i shall get a photo to show you soon.
its beyond me, just trying to figure out why before i hack it out.
i have had most of dash apart today and apart from that horrific alarm wiring all else seems fine and after my tidy wiring work is looking very good now.
i shall be sorting c101 during the week and hopefully all should be well when i drop new engine in.
e30mtech
Post Mon Oct 10, 2011 8:24 pm
well traced the other red into centre console and found another shambles. yet another alarm part and more taped together wires!!
removed that and dash all ready to put back together.
quite a pile of wires removed
here are some pics of the wire that runs to the fuse box to that plug/blank took a couple to see if you have any idea why
you reckon it cool to just hack it out brian?
i reckon if its cause somethings not working i could do a much better job repairing it than that lol
Post Mon Oct 10, 2011 9:55 pm
The three pin socket inside the fusebox is where part of the aircon wiring plugs in!
It looks like the red wire is pushed into the socket with the green/black wire, which is ignition switched live from fuse 19.
I suggest you remove all of the added in wiring, plus the alarms, and then see what you have left.
Some of your fuses appear to be rated quite a bit higher than they should be as well!
Post Mon Oct 10, 2011 9:59 pm
an Alarm fitter strikes again, yours must have been expertly fitted, there's no scotchblocks :eek:
e30mtech
Post Mon Oct 10, 2011 10:16 pm
correct
2 alarm systems removed a moss security and a limwood thing
absolute bodge, the moss was wired into the passenger window control!
i thought that as well.
dash is all tidy now almost completely as it should i shall finish off tomorrow. all i need now is c101 connectors to finish wiring completely,.... for now until i drop engine in and see if i have any problems lol
thanks again brian you have been most helpful as always no doubt there will be more to say on this lol
