What was that black stuff? Also, best post-weld primer??
BigDave1
Post Sun Oct 02, 2011 4:23 pm
1. Black stuff? -I've just cut and ground out the entire outer rear wheel housing section on my M-tech 2 325i Sport (1988). This is the inner section that butts up against the inside of the off-side rear wing. My question is what exactly was the black paste I found smeared liberally around the petrol flap hole between the rear wing and the wheel housing? I assume it was bitumen of some sort to stop the vibration between these two sections because they sit so close together when assembled? Rather than smear something equally messy there upon reassembly I'm tempted to cut out some anti-vibration/sound deadening material to stop any potential vibrations. Has anyone else done this or should I just reapply the black paste?
2. Post-Welding Primer. Once I have welded in the new housing and patch-welded a couple of other rust holes, I want to spray the welded arears with some primer that protects the weld and stops new rust appearing there. I've heared that red oxide primer is porus and doesn't stop the rusting process on it's own. What is the best stuff to use? Perhaps someone also knows about applying seam paste, which I guess is applied to the weld or a panel join area after the primer has dried.
Your thoughts? :D
badboye21
Post Sun Oct 02, 2011 6:10 pm
there is an etch primer available called acid 8 i think by upol it comes in an aerosol or in 1ltr cans to put on with a gun couple fo coats of that should do you. I would use a brush on seam sealer after this and to make sure if you want a long lasting repair spray some paint in there.
Malc
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Oct 02, 2011 6:59 pm
From bare metal to paint, here's every step of the chemical process:
http://www.e30zone.net/modules.php?name ... 42#2256342
All the old brushable stuff is porous, but then again so are all the new spray primers. That's what the anti-rust sprays are for.
BigDave1
Post Sun Oct 02, 2011 9:05 pm
Guys. Very many thanks for the post-welding / pre-paint advice, and the link - good stuff.
Does anyone else have any comments about the black paste (bitumen?) around the petrol filler hole?
