How easy is it to convert 4 stud to 5 stud ??????????
Jibberingloon
Post Thu Sep 29, 2011 9:06 am
Running 325 Sport Running Gear..
Want to go to 5x120
How easy is this?
Whats the sort of cost?
Thanks :mad:
Post Thu Sep 29, 2011 9:15 am
Easy - fit M3 suspension.
Cost - !!!!!!!!!!!!!!!!!!!!
Motorhole
Post Thu Sep 29, 2011 9:21 am
Two ways, 1 easy, 1 hard, both expensive!
1) E30 M3 running gear - expensive, hard to find, but bolts on easily.
2) E36 Compact/Z3 rear end. Front needs to be E36 struts (use either E36 M3 evo or a coilover) with E36 M3 Evo hub assemblies and control arms. E30 M3 eccentric controla arm bushes should be used. It's critical that the E36 M3 EVO hub assemblies and control arms are used as otherwise the castor won't be right, the wheel won't be centred in the arch and handling will be crap. Bonus though is you get E36 M3 Evo front brakes.
Note that the 2 setups require different offset wheels to fit. Can't remember the numbers off the top fo my head, but with the E36 setup you will need E36/E46 offset wheels. With the E30 M3 setup, you will need E30 M3/E34 offset wheels.
I'm in the process of doing this but I'm beginning to think it might not be worth it for the outlay! You do get bigger brakes and wider track. But all in, the E36 setup will cost at least £700-£800 if you also want new discs and pads. Even more if you want recon calipers and new wheel bearings and more again if you go the coilover route as I have.
Next time I will stay 4-stud!
xavier
Post Fri Sep 30, 2011 12:08 am
Can you still but the M3 parts anywhere apart from finding a wrecked one? Does BMW still make the parts? I would hate to imagine how much they charge if they still do make them
Barx325i
Post Fri Sep 30, 2011 12:36 am
xavier wrote:Can you still but the M3 parts
which m3?
Kos
Post Fri Sep 30, 2011 12:40 am
xavier wrote:Can you still but the M3 parts anywhere apart from finding a wrecked one? Does BMW still make the parts? I would hate to imagine how much they charge if they still do make them
front strut bare is about £700 hub/bearing is another £300. so thats 2 k for the front with out brakes. rear hubs are 250 give or take to thats £2500
used M3 set up is about £1250 on a good day
Barx325i
Post Fri Sep 30, 2011 12:44 am
but, depreciation is zero, given you don't roast the bearings
xavier
Post Fri Sep 30, 2011 6:25 am
holy s?#$%
KCRanger
Post Fri Sep 30, 2011 2:36 pm
Are e30 M3 struts required to use M3 hubs or can a standard e30 strut set up also use the M3 hubs? :?: :roll: :?:
nickso
Post Fri Sep 30, 2011 6:19 pm
KCRanger wrote:Are e30 M3 struts required to use M3 hubs or can a standard e30 strut set up also use the M3 hubs? :?: :roll: :?:
nope different size.
'88 e30 328i M52 track bint.
Gouki
Post Fri Sep 30, 2011 6:39 pm
I will be doing a 5 stud conversion using the E36 setup. Working out although its expensive its nowhere near as mad as buying a used E30 M3 which are near enough like gold dust and from I been told by a very good friend if you need to replace a wheel bearing on them they aren't cheap!
Some good info from the boys across the pond.
http://e30tech.com/forum/forumdisplay.php?f=52
nickso
Post Fri Sep 30, 2011 6:43 pm
E28 wheel bearings fit and are not bad for price.
Phill172
Post Mon Oct 10, 2011 2:49 pm
£700!!!! Its really not that pricey, I may be a cheap skate but if you hunt about it can be done cheap. There is no harm looking second hand.
I only changed to 5 x 120 as it was much easier to find wheels and to also re-drill the hubs to 5 x 114.3.
The brake benefits are huge too, although saying that I built my car with one of the top PBMW race-car builders and they simply uprate the pads/good quality discs, braided lines and fluids and that is more then enough meat for a full race let alone track day.
But if you do change to E36 M3 Evo kit, the brakes in standard form are more then enough for a E30.
I picked up wishbones from ebay for 99p, M3 evo ones, just take your time and pick all the bits up. There are plenty of breakers out there and you can recon the calipers yourself if you think they need doing.
I managed to do my whole set up including full rears all polybushed for about £150, and it simply all bolts on. You do have to change one of the top mount bolt holes and thats it.
All this lark about crap handling etc, is shite, assuming it being a track car no doubt you will be using fully adjustable top mounts, with this you can dial the front setup exactly how you want it.
Offsets on wheels depends on what wheels you run, Im running 17 x 8.5j et 15 (inc 20mm spacers, although the scrub radius fucks it up) and they tuck in a hell of alot! Although im running alot of camber they tuck like this
For the gain, I couldnt believe how cheap and easy it all was :)
e30mtech
Post Mon Oct 10, 2011 7:28 pm
bmw wheel fitments and offsets
http://www.gruppeb.com/BMWwheels/fitments/
