£700!!!! Its really not that pricey, I may be a cheap skate but if you hunt about it can be done cheap. There is no harm looking second hand.
I only changed to 5 x 120 as it was much easier to find wheels and to also re-drill the hubs to 5 x 114.3.
The brake benefits are huge too, although saying that I built my car with one of the top PBMW race-car builders and they simply uprate the pads/good quality discs, braided lines and fluids and that is more then enough meat for a full race let alone track day.
But if you do change to E36 M3 Evo kit, the brakes in standard form are more then enough for a E30.
I picked up wishbones from ebay for 99p, M3 evo ones, just take your time and pick all the bits up. There are plenty of breakers out there and you can recon the calipers yourself if you think they need doing.
I managed to do my whole set up including full rears all polybushed for about £150, and it simply all bolts on. You do have to change one of the top mount bolt holes and thats it.
All this lark about crap handling etc, is shite, assuming it being a track car no doubt you will be using fully adjustable top mounts, with this you can dial the front setup exactly how you want it.
Offsets on wheels depends on what wheels you run, Im running 17 x 8.5j et 15 (inc 20mm spacers, although the scrub radius fucks it up) and they tuck in a hell of alot! Although im running alot of camber they tuck like this
For the gain, I couldnt believe how cheap and easy it all was
