Temperature gauge doing strange things.
ah
Before I start I have put a new a new sender unit on it about six months ago.When I turn the ignition on the needle sometimes cranks over to left of centre,but then it just touches the first line.Today I noticed the needle just touches the blue area,whats going on?
Born on the 23 April 1990 320i Alpinweiss ll kabriolett! (SOLD BUT NOT FORGOTTEN !)
Tightened the small brass nut on the back of the cluster?
ah
Cheers Brian,do the nuts have to be brass as one was missing and Ive replaced it, but it was a steel nut.would this cause any problems.
Better than none. Should be OK unless it corrodes, and if you get corrosion in this area, then a temp. gauge problem is the least of your worries!
