swapping injectors?
Cloggy Saint
Post Sat Sep 24, 2011 6:46 pm
Is it better/easier to remove and refit the injectors while still attached to the fuel rail or first remove the rail and then do them one by one?
Jim320i
E30 Zone News / COTM Team
Post Sat Sep 24, 2011 9:30 pm
I would remove the rail first as you get more 'angle' when pulling them out, where as when they are still attached to the rail, you have limited movement :?
One of them jobs I keep putting off. 8O
Post Sat Sep 24, 2011 9:36 pm
which ever way you choose just try to pull them out straight you don't want to leave a pintle cap behind :eek:
it makes the job easier if you spray wd40 towards the base of the injector where it goes into the inlet to lube the o ring that holds them in
**BANNED**
Post Sun Sep 25, 2011 7:18 am
When you lift the fuel rail out,you will find that some injectors will come with it,and some will be left behind.
Fiddle the fuel rail out toward the front of the engine,it's easier if you dis-connect the temp sensors and remove the injector sub-loom first,take note of the way it threads through the manifold to C191.
The support bracket from the rocker cover to the inlet will need removing so that you can see what you are about,and the fuel rail is held by four 10mm bolts.
M20 injectors are a proper PITA to remove,M50 are a doddle by comparision!
Youth is wasted on the young.
Cloggy Saint
Post Sun Sep 25, 2011 8:05 am
A proper PITA eh? Sounds like fun. Thanks for the info.
E30Gheko
Post Mon Sep 26, 2011 12:32 pm
I've done this a few times on M20's and always managed to remove the injectors still attached to the fuel rail. Once removed it's a doddle to swap them and then refit the whole thing.
