Recently I swapped my stock steerring wheel (380mm) with an nice old-skool momo (350mm). All tho only 30mm smallrt, this wheel feels much better. the slow steering rack isin't an issue any more. And my legs finally fit under the steering wheel (they used to rub which was really annoying in the corners). Essentially it's great and I dont want to go back to stock...
THe problem... now I cant see the top halves of the speedo and rpm gauges, which is pretty bad as past 60 mph i dont know how much I'm doing, likewise over 2k rpm, i runno what the rpm's are until they get to about 6
My car does not have adjustable steering column
Is there any way to manually adjust steering column upwards ??? Like undoo it from the mounts and fabricate some spacers or custom brackets ? even slight adjustment would be halpfull, and if I could move it 1" higher then it would be just perfect.... anybody did something like this before ?
Thanks in advance,
