Sheared bolt on thermostat housing
Touring_IOM
Post Wed Sep 21, 2011 7:19 pm
Ok, so tightening a bolt on the thermostat housing after replacing the thermostat and got to a good tightness tightness with a 10mm spanner then put the torque wrench on to make sure it was correctly torqued. Suddenly it got extremely loose took the wrench off and seen the bolt on wrench. Now I don't know what to do; I have no welding skills nor welding equipment, I could see me buggering up the hole with a drill and I have tried mole grips to no luck. Now I don't know what to do. :cry:
Here you can see what I have to play with. about 3mm poking out.
It's a little out of focus but what could I do with this.
Post Wed Sep 21, 2011 7:29 pm
unless you can drill tap it then unbolt the housing, and fit another. Its held on with 2x12mm nuts. They might be 13's if someone has been there before.
Be warned these can be tough to get off if the studs are corroded to the stat housing. Don't FFS snap one or your in a word of sh!t. If it looks a bit dicey a heat gun and some penetrating fluid are your friend
Touring_IOM
Post Wed Sep 21, 2011 7:56 pm
Where are these bolts held? I could see that happening so get some good penetrating fluid and I'll see if I can get hold of a heat gun.
I'll let you know how I get on. :wink:
turkeysneck
Post Wed Sep 21, 2011 8:11 pm
That's a recipe for disaster , I'd find an engineering firm who has a spark eroder. At the very worst they will drill and tap it or helicoil it. If you attempt it yourself you'll ruin it.
Touring_IOM
Post Wed Sep 21, 2011 8:21 pm
turkeysneck wrote:That's a recipe for disaster , I'd find an engineering firm who has a spark eroder. At the very worst they will drill and tap it or helicoil it. If you attempt it yourself you'll ruin it.
It truly is, especially on a part that is quite important. So can the bit that I have f***** up not removable and cannot be replaced? The problem is, I can't move the car and I am strapped for cash also I don't know any places on the Isle of Man. :( I'll have to ask around I think.
kyland
Post Fri Sep 23, 2011 1:29 am
You could try using a hacksaw to cut a slot in the end of the broken bolt and then turn it out with a screwdriver perhaps?
clipper
Post Fri Sep 23, 2011 7:31 am
I snapped a sump bolt which only had about 2-mmm protruding, so I selected a Torx socket which wouldn't quite slide over the exposed part of the bolt, tapped it on with a light hammer, the torx socket gripped prety well even with only a few mm to go on due to the way the thread deformed evenly and allowed me to wind out the bolt.
Might work for you too.
Touring_IOM
Post Fri Sep 23, 2011 10:41 am
kyland wrote:You could try using a hacksaw to cut a slot in the end of the broken bolt and then turn it out with a screwdriver perhaps?
Would the screwdriver not just slip out? as 2mm is not a lot to play with :/
Touring_IOM
Post Fri Sep 23, 2011 10:46 am
clipper wrote:I snapped a sump bolt which only had about 2-mmm protruding, so I selected a Torx socket which wouldn't quite slide over the exposed part of the bolt, tapped iton with a light hammer, the torx cket gripped prety well even with only a few mm to go on due to the way the thread deformed evenly and allowed me to wind out the bolt.
I'll definitely have to try that, thanks!
Touring_IOM
Post Fri Sep 23, 2011 5:08 pm
Right after a whole day trying every method including using a torx socket, hack saw and screw driver, I also tried to take it off but I can't find the two 13mm bolts so I think i'll have to get a mechanic or something to come up and sort it. Thanks guys for your help at least I can get on with other jobs winkeye
powelly
Post Fri Sep 23, 2011 8:07 pm
Unless it's seized in that should unwind easily, if it's tight then you must have bottomed the bolt out somehow and that broken bit is still under load, to be fair that actually looks to me like a reasonable amount to get a purchase on with some mole grips, use some plus gas to help and a as Si said a heat gun might help a bit, certainly won't get eneough heat in to damage anything.
Image Le Mans Classic 2006
Touring_IOM
Post Fri Sep 23, 2011 8:17 pm
powelly wrote:Unless it's seized in that should unwind easily, if it's tight then you must have bottomed the bolt out somehow and that broken bit is still under load, to be fair that actually looks to me like a reasonable amount to get a purchase on with some mole grips, use some plus gas to help and a as Si said a heat gun might help a bit, certainly won't get eneough heat in to damage anything.
It is a good size but the bolt has ended up like this: > (Sorry best way to describe it.) So the mole grips just slid off without getting and purchase on it. I have some mini files to file it down but it does not work. Would heat help the problem here?
Post Fri Sep 23, 2011 10:29 pm
The two studs that hold the thermostat housing are in line with the studs that hold the inlet manifold on. The 13mm nuts shouldn't be hard to find. Take out the air filter/meter for access.
Faced with your broken stud, I would drill a tight fitting hole in a small square piece of flat steel, lay it over the remains of the stud, weld it in place, then wind it out with a spanner on the steel. The thermal shock from the welding is very effective at freeing seized bolts.
Post Fri Sep 23, 2011 10:48 pm
I come across this regular,
the housing isn't expensive new from the dealers IIRC, what also happens with them is the smaller pipe on the bottom snaps/shears off very easily
Post Sat Sep 24, 2011 6:48 am
Steve. It's nowt to do with bottoming out mate. It's a pre placed stud that the housing slides over, not a long bolt. They seize due to minute coolant weeps, the reaction between the alloy housing and the steel bolt and the vastly different heat ranges.
As for hacksawing a slot? if it sheared using a spanner, theres not much chance with a screwdriver.
As Brian says, the bar and weld trick is probably best or a 13mm nut welded in place.
