Cylinder Head Bolts
TPS
Post Sat Sep 17, 2011 6:36 pm
I've got to take off an head off a facelift 320 engine, does anyone know if the bolts are the torx or hex type?
**BANNED**
Post Sat Sep 17, 2011 6:49 pm
If they are hex bolts,do not put them back!
It's the hex-headed bolt heads that snap off,get under a rocker and cause mayhem.
Buy a set of torx streech bolt to re-build with.
Youth is wasted on the young.
TPS
Post Sat Sep 17, 2011 6:55 pm
If they're torx, what size socket do I need?
**BANNED**
Post Sat Sep 17, 2011 7:04 pm
E14! :D
No idea about the hex-headed one's,but an educated guess would be 13mm.
Post Sat Sep 17, 2011 7:09 pm
Hex heads are 17mm, the torx size is 14, it's facelift so it will be torx :)
TPS
Post Sat Sep 17, 2011 7:52 pm
Thanks Malcolm/Steve, luckily the Engine is on the garage floor, so should be alot easier to work on!
Andyboy
Alpina Colada
Post Sat Sep 17, 2011 8:30 pm
e30topless wrote:Hex heads are 17mm, the torx size is 14, it's facelift so it will be torx :)
Not always. Torx head bolts were introduded early 1989.
TPS
Post Sat Sep 17, 2011 8:32 pm
The engine is from 1988
Andyboy
Alpina Colada
Post Sat Sep 17, 2011 10:29 pm
It will have left the factory with 17mm hex, unless they've already been changed. Keep the fat washers and use them on the new torx bolts.
TPS
Post Sun Sep 18, 2011 7:57 am
Thanks Andy, I'll let you know how it goes.
TPS
Post Sun Sep 18, 2011 11:32 am
They were 17mm Hex, undid them a quarter of a turn at a time, in sequence, according to the Bentley book. Got splattered with petrol, where the FPR was still attached, apart from that, Surprisingly easy in the end, thanks for everyones help.
retroboyo
Post Mon Sep 19, 2011 10:47 am
Do you have to use new head bolts if you take the head off, I'm about to do mine
TPS
Post Mon Sep 19, 2011 10:51 am
Yes, don't re-use the old ones, also make sure when your tightening/loosening the bolts, they're done in the right order.
retroboyo
Post Mon Sep 19, 2011 11:13 am
Thank you
