Can you put a 325i inlet and TB onto a 320i out of curiosity?
Anything else need to be changed if you do apart from a few of the obvious things?
Would it run right?
M20 inlet manifold question
Duke137
Cue the standard "fit the rest of the engine while you're at it" response
Ajsingh
It would fit, but u would have to trim the ports on the 731 head.
Iv heard on before that there is no real point and does not add really anymore performance or power... And its a fair bit of work for no gain... The b20 stroke is what is useless
E30 Crazy!
Ajsingh
+1capri_rob wrote:Cue the standard "fit the rest of the engine while you're at it" response
E30 Crazy!
Duke137
Thats fine and just interested if it made any odds like the M50 inlet mod
Ajsingh
Believe me if it did, my car would not be a 2.7 right now lolDuke137 wrote:Thats fine and just interested if it made any odds like the M50 inlet mod
E30 Crazy!
Andyboy
- Alpina Colada
The 320i responds well to a manifold swap and bigger throttle body - they're very strangled as they are. You need to lay a 325i manifold gasket on the head and using a die grinder, open out the shape of the ports. You will 101% need a remapped ECU though to get any benefit - 320i's are quite underfuelled as it is without any more air going in. It's a short stroke big bore engine that revs nicely. It'll never be fast as such but you can certainly make them better.
An easier alternative is to fit a 325i throttle body, but you need to do a pretty intense bit of grinding to open out the 320i manifold.
Duke137
Sounds just as easy to drop a b25 engine in reality....Andyboy wrote:The 320i responds well to a manifold swap and bigger throttle body - they're very strangled as they are. You need to lay a 325i manifold gasket on the head and using a die grinder, open out the shape of the ports. You will 101% need a remapped ECU though to get any benefit - 320i's are quite underfuelled as it is without any more air going in. It's a short stroke big bore engine that revs nicely. It'll never be fast as such but you can certainly make them better.
Cheers Andy
