E30 Cossie Project
MurphyE30
Post Thu Sep 08, 2011 9:28 pm
Following on from my previous build thread
http://www.e30zone.net/modules.php?name ... c&t=201335
I have started this thread in the Engine swaps section as most work to be done now will be focused around the build
Where do i start? well as some of you know I got this turd a while back and I was going to fit the 2.7 from my cab, I then decided to sell on the 2.7 with the intensions of going the M52B28 route, after a few complications I took the plunge and sourced a good low mileage M52 from a 728i Auto with FSH ect.. and started collecting the conversion parts.
Then when browsing through the for sale section last week I noticed Umar's advert for Fuzzy's cossie conversion set up and adecided to go for it :) So the M52 was to be sold on.
I've always been into Fords, mainly XR2's and RS turbos. but have always wanted for a nice Saph cossie but never been able to afford the premiums in the past. So to go for the chance of putting a cossie lump into my E30 seemed to good to miss.
I'm off down to collect the E30/Cossie conversion parts on Saturday which includes: Left & right arms that bolt to the engine and then fit on to standard 325i engine mounts, they have been painted with hammerite black and are made out of roughly 10mm steel angle
Modified Sump that has been tig welded to clear the E30 crossmember
Modified oil Pick Up pipe to go with the sump
Modified wiring loom to fit to the e30 engine plug in the engine bay, the loom has been re-covered with harness tape.
Custom Prop, half e30 and half Ford that has been hammerited in black
Modified gear selector
Modified clutch fork for use with the E30 master cylinder
so from then I will be starting to get together the further bits I will need for the conversion, currently looking into a possible Donk thats available for when I have the funds together, a Stage 3 lump from a RWD saph which will have the RWD gearbox needed and ECU.
The car has had a bit of work done since the last time I posted, been into the bodyshop to have my Tech II kit fitted, rear pop out fitted and a nice set of 9j Borbet A's
Also got an E46 3 turn Quick rack coming from Dan who has been a great help with info to help me out :)
Have say a big thanks to Mick for all the help so far geting this one sorted out :)
heres a few pics of the car as it stands
Post Thu Sep 08, 2011 9:31 pm
Car has come a long way Ben and looks very nice and she's a proper solid old girl too.
Kudos on the YB swap, she'll be rapid, ya cooont :)
fuzzy
He who sleeps with "Gingers"
Post Thu Sep 08, 2011 9:38 pm
youve went down the same route as me on many of the options.good luck with it but i hope youve got deep pockets.....
Post Thu Sep 08, 2011 9:39 pm
Fook!!!!
Looks like it'll go nicely with Fuzzy's old lump in her. 8)
leeparkes
Post Thu Sep 08, 2011 9:42 pm
fuzzy
Post Thu Sep 08, 2011 9:43 pm
is it my old engine? i didnt know that.ive been away for a while .
Ali786
Nice one mate it looks good with the tech 2 kit stuck with the borbets :cool: how much bhp you lookin at with the cossie conversion? Good luck with it
Blue 1988 320i convertible
MurphyE30
Post Thu Sep 08, 2011 9:48 pm
E30BeemerLad wrote:Car has come a long way Ben and looks very nice and she's a proper solid old girl too.
Thanks Lee she's getting there slowly :)
fuzzy wrote:youve went down the same route as me on many of the options.good luck with it but i hope youve got deep pockets.....
Pockets aint deep but working alot to fund it :lol:
Any advice/info you may be able to give me on the conversion/set up would be a great help :)
there dosent seem to be any comprehensive build threads available
Rav335uk wrote:Fook!!!!
It wont be Fuzzy's lump mate just all the conversion parts, the lump im looking at is a stage 3 spec YB belonging to a mate of mine
fuzzy
Post Thu Sep 08, 2011 9:57 pm
itll go like fook and will be great fun. i had a stage 3 conversion with a stage 2 t34 in mine.
MurphyE30
Post Thu Sep 08, 2011 10:05 pm
Yeah I imagine it will be a hoot to drive :)
did you have a build thread Fuzzy? I had a look for one but was only able to find some pics of yours
fuzzy
Post Thu Sep 08, 2011 10:19 pm
no, no build thread, just some pics that are now on page 8 of the members e30 section.i had many problems that were mainly due to the donkey that did most of the work. cost me a couple of grand to put right but it worked out in the end.got bored of it after a while though and broke it up for parts when i split from my ex missus nearly 2 years ago now. traction will be a problem.....
e30-EVN
Post Fri Sep 09, 2011 11:16 pm
sounds like an amazing project mate i'll give you that!
i wish you luck with it, could be a hole load of fun,,, imagine it on boost in 3rd in the wet 8O 8O :cool:
ross2009
Post Sat Sep 10, 2011 11:34 pm
looking good matey cant wait to see it done maybe next year winkeye
Turbo M20
v8 project 6.0 twin turbo
Post Sun Sep 11, 2011 1:42 am
your a coont :D
MurphyE30
Post Mon Sep 12, 2011 6:15 pm
ross2009 wrote:looking good matey cant wait to see it done maybe next year winkeye
I'm looking to have the £££'s for the Engine/Box/ECU together by the end of this year. so could be done toward middle of next year :D
What radiator are you using with your set up mate? from what I've been told to fit the Cossie rad notches have to be taken out of the chasis legs for it to slot into because its alot wider, so need to find a suitable rad
ross2009
Post Mon Sep 12, 2011 6:53 pm
I've just got a normal rad in mine but have thought about getting a ali one for it
Turbo M20
MurphyE30
Post Mon Sep 12, 2011 7:27 pm
I had thought about an olloy rad but i suppose i would have to have one made to suit.
from looking at the likes of BurtonPower the alloy rads are between £300-500 ish
so unsure on what sort of price a custom one would be
Any updates on yours? :)
ross2009
Post Mon Sep 12, 2011 8:09 pm
I've seen some on eBay but there in the states had alook yesterday but they ain't on there anymore
they worked out to be about 250 shipped
mines getting there done about 950 miles now mate so gonna change the oil soon
might have ago at getting it running on ms next week or just wait for ant to do it :)
Turbo M20
Ali786
Post Fri Sep 30, 2011 10:15 pm
any updates??
