Spec;
M50 2.5l non vanos engine
Viper chipped ECU
Wiring loom modified by Danthe
M20 lightened flywheel + M20 starter motor
New Sachs clutch
Enlarged Throttle body
E28 M5 engine mounts
M40 gearbox with M20B20 gear selector linkage
320 Prop
Clio servo and spacer
Stainless exhaust and modified headers
M40 radiator with fan mounted on front
I'm very excited to start it but first I will need your help...
Bits that I need:
E34 525 throttle cable
fan loom (already dealed with Dan)
Maybe a bigger radiator and a twin speed fan
an LSD
Loads and loads of information..
In the same time:
I will also change the steering rack with an e36 one (I have all the bits from Dan)
Clean the engine bay
I'm waiting for your inputs and advices!
