My M50 conversion
StefanAnghel
Post Mon Sep 05, 2011 7:42 am
...well kind of...as I bought it as a "weekend kit" :D from Alex (MrBenn) and was originally Dezzy's creation...
Spec;
M50 2.5l non vanos engine
Viper chipped ECU
Wiring loom modified by Danthe
M20 lightened flywheel + M20 starter motor
New Sachs clutch
Enlarged Throttle body
E28 M5 engine mounts
M40 gearbox with M20B20 gear selector linkage
320 Prop
Clio servo and spacer
Stainless exhaust and modified headers
M40 radiator with fan mounted on front
I'm very excited to start it but first I will need your help...
Bits that I need:
E34 525 throttle cable
fan loom (already dealed with Dan)
Maybe a bigger radiator and a twin speed fan
an LSD
Loads and loads of information..
In the same time:
I will also change the steering rack with an e36 one (I have all the bits from Dan)
Clean the engine bay
I'm waiting for your inputs and advices! :D
StefanAnghel
Post Mon Sep 05, 2011 7:48 am
During transportation
Resting in the garage
Exhaust system...I just need a tailpipe... :D All ideas are welcomed!
randomspeedfreak
Post Mon Sep 05, 2011 10:10 am
i envy how much time and money you have saved yourself doing it this way!
StefanAnghel
Post Mon Sep 05, 2011 11:31 pm
Dezzy can you tell me if you also changed the thermostat with the water pump? blue and brown sensors?
Thank you
Until I have everything and I'm ready to do the conversion should I put some oil in it and turn it every couple of days?
StefanAnghel
Post Thu Sep 08, 2011 7:26 pm
Can someone post some pictures with their m50 conversion?!
Also I'd like to ask if the best diff ratio to use for my concersion is 3.64?!
Best for mpg and acceleration...
Thank you!
Post Thu Sep 08, 2011 7:44 pm
3.64 - best for MPG, 3.91 best for acceleration
What pics do you want of the conversion?
Look up E30-DK's swap thread as Ant put up some useful pics. There will be pics in my thread, but it's over 100 pages now :mad:
e30-EVN
Post Thu Sep 08, 2011 11:03 pm
ive bumped my thread up to the top for you mate 8)
and anyone else who may need the help from pics :)
StefanAnghel
Post Fri Sep 09, 2011 9:14 am
Thank you
My first mission is to clean and paint the engine and maybe the gearbox...
What paint should I use.. Very high temp (up to 600'c) or just high temp (up to 300'c)?
I have some problems with the engine crane also.. Doesn't lift on load but it's fine empty.. I've top it up... And it's the same! Any suggestions!?
e30-EVN
Post Fri Sep 09, 2011 4:28 pm
i used alpine white 2 from bmw mate,,, it fine 8)
my only beef with that was the price...... £13 for 150m can 8O
a can of coke is bloody 350m lol......
cant offer any advise on the crane sorry, strange apnin that... hope someone else can shed some light :)
StefanAnghel
Post Sat Sep 10, 2011 12:52 am
e30-dk wrote:i used alpine white 2 from bmw mate,,, it fine 8)
For the engine you used alpine white?! :mad:
From where did you buy the exhaust copper nuts?
e30-EVN
Post Sat Sep 10, 2011 12:31 pm
Sorry my mistake lmfao, noooo I didn't.
Used it on my engine "bay" lol :mad:
Got the manifold nuts and studs from bmw for a few quid 8)
StefanAnghel
Post Thu Sep 15, 2011 1:29 am
Right...I've start today with a bit of cleaning
Questions :
what paint should I use? Very heat temp (up to 600) or heat temp paint (150- 300)?
And
my e30 has the fuel filter at the back just outside the fuel tank, is it ok to use that filter and to remove the M50 one next to the starter motor??..as it will be a pain to be changed when the engine is in?
thanks
StefanAnghel
Post Fri Sep 16, 2011 9:20 pm
More cleaning and prep for painting
and first problem...
StefanAnghel
Post Fri Sep 16, 2011 9:27 pm
Few questions again...
what is this first sensor (the one in the left as you look at the picture)?
also for what is that plug under the sensors as I've seen on the realoem that is some king of throtle body cooling?
and why so many blocked hoses?
Post Fri Sep 16, 2011 9:57 pm
You took the loom off I take it? The sensors, left to right are Blue sensor for ECU, Brown sensor for gauge (should have been changed for an E30 one) and the one on the right is just there to block the outlet for throttle heater, the hose with a bolt in is the return from the throttle heater. The pipe under the throttle body is the vacuum connection for fuel tank vapour valve which is long gone
Duke137
Post Fri Sep 16, 2011 9:59 pm
StefanAnghel wrote:Few questions again...
I stuck a sump nut in the right hand one to plug it up, looks loads neater
StefanAnghel
Post Fri Sep 16, 2011 10:11 pm
Thanks Dan...from left to right as you look to the picture? because I've found the first in the left not connected the middle one connected to the brown connector and the one one int right was with the blue connector?!? pics like i've found them...
What for throtle heater? any good to put it back?
StefanAnghel
Post Fri Sep 16, 2011 10:15 pm
Can I remove the drive belt and put it back without silly problems and adjustments like on the M40? (where the accesories belt is the cambelt also)
e30-EVN
Post Fri Sep 16, 2011 10:26 pm
i removed mine mate, before i dropped the lump in i changed for a new belt and tensioner pulley....
StefanAnghel
Post Fri Sep 16, 2011 10:32 pm
mine looks new...but I want to remove it to be able to clean and paint the block...so i'ts safe to do it?
e30-EVN
Post Fri Sep 16, 2011 10:33 pm
yeah totaly safe man. mine looked new aswel but for the sake of a few quid i changed it anyway..... piece of mind thing also like ya know :)
StefanAnghel
Post Fri Sep 16, 2011 10:46 pm
e30-dk wrote:yeah totaly safe man. mine looked new aswel but for the sake of a few quid i changed it anyway..... piece of mind thing also like ya know :)
OK, Thanks...I'll do that tomorrow morning...and after that maybe changing that gasket between the oil filter housing and engine if that was not done by Dezzy
StefanAnghel
Post Fri Sep 16, 2011 10:59 pm
I've just found this picture on Dezzy's original topic about my engine and noticed the pipe, means that I have two blue sensors?
Dezzy
CR24v it's a lifestyle
Post Sun Sep 18, 2011 9:26 pm
The blue and brown sensors were E30 ones when it was in and running in my moredoor. Dan used the other sensor as a blank.
I never had the oil filter housing off mate.
Post Sun Sep 18, 2011 9:57 pm
StefanAnghel wrote:Thanks Dan...from left to right as you look to the picture? because I've found the first in the left not connected the middle one connected to the brown connector and the one one int right was with the blue connector?!? pics like i've found them...
As long as they are both blue sensors in full working order, it isn't going to matter which you connect to.
Post Sun Sep 18, 2011 10:05 pm
StefanAnghel wrote:Can I remove the drive belt and put it back without silly problems and adjustments like on the M40? (where the accesories belt is the cambelt also)
The accessories belt on a M40 is not also the cambelt. Only rubbish like Vauxhall do things like that!
M40 uses a toothed flat belt to drive the camshaft only.
Oil pump is driven directly off the crank, and water pump, alternator, power steering and aircon are driven by one or more vee belts. Can be four belts on an M40.
Serpentine belt on an M50 doesn't time anything, and is automatically tensioned, so is easy to remove and replace, but draw a diagram of how it runs first.
StefanAnghel
Post Sun Sep 18, 2011 10:47 pm
Brianmoooore wrote: The accessories belt on a M40 is not also the cambelt. Only rubbish like Vauxhall do things like that!
Now I realised that I was talking crap... I don't know at what I was thinking...I only know that M40 needs to be blocked/marked when you change the timing belt...and was a pain to be done...
I removed it and I took pictures of everything before! winkeye
I was thinking now that I have the engine out to change and clean/recondition everything that might be a problem later on...does anyone have any suggestions?!
Also I was thinking at some extra gauges (oil temp, oil presure and something else) are they hard to be fit?
Post Sun Sep 18, 2011 10:54 pm
Oil pressure gauge usually involve fitting a tee piece in place of the existing switch, then screwing the original switch into the one of the female ports on the tee, and a capillary tube or electric pressure transducer into the other port.
Oil temp gauge fitting involves either fitting a thermistor into the sump pan, or into the sump plug.
StefanAnghel
Post Sun Sep 18, 2011 11:18 pm
Brianmoooore wrote:Oil pressure gauge usually involve fitting a tee piece in place of the existing switch, then screwing the original switch into the one of the female ports on the tee, and a capillary tube or electric pressure transducer into the other port.
Thank you
Any pros and cons? what the 3rd gauge to be for?
Post Sun Sep 18, 2011 11:24 pm
3rd gauge?
StefanAnghel
Post Mon Sep 19, 2011 12:16 am
I've seen that instead of ashtray can be fitted 3 gauges...I'm not a smoker so what other gauge will be good on the m50?
Green
Post Mon Sep 19, 2011 1:11 am
Guess you could have voltage.. although to be fair on a road car all those seem a little over the top.
StefanAnghel
Post Mon Sep 19, 2011 9:57 pm
Green wrote:Guess you could have voltage.. although to be fair on a road car all those seem a little over the top.
I know they are a bit over the top..but if can be done and looks stock and helps the good health of the engine...why not??
I might take the turbo way after I get bored with the stock M50.. winkeye
Small shot to show you how the e30 looks on brock b1 with KW coilovers...at the moment as high as it's possible...
StefanAnghel
Post Sat Sep 24, 2011 5:41 pm
more cleaning...
Before:
After:
StefanAnghel
Post Sat Sep 24, 2011 5:46 pm
I'll paint the engine block with por15 engine enamel...red
should I leave the Gearbox and Sump like that or sealed them with something?
