M20B25 Poor Running
Kedge
Post Fri Sep 02, 2011 3:35 pm
Hi,
I was going to be posting a question any way about my touring as it really struggle to tick over until it's warm, but i was driving fine as soon as it was warm, thinking that could be a coolant temp sensor??
However today it's still doing the above however it's now driving like a bag of crap. Really hesistant and lumpy on anything other than full throttle and keeps stalling as soon as you stop.
Could this also be related to the coolant sensor or more TPS? Also a little suspect of the AFM meter since it's missing it's plastic cover, picking up a replacement on Sunday to rule that out.
Dave
Instagram - Kedge85
toby
Post Fri Sep 02, 2011 3:39 pm
Check for air leaks in all the rubber bits around the air flow meter. Check all other basics like plugs etc
**BANNED**
Post Fri Sep 02, 2011 3:40 pm
Got a meter?
Check the resistance across the pins of the blue sensor with the engine cold,and with the engine hot.Should be a big difference in the reading.
To eliminate a wiring fault,repeat the check at the ECU plug.
Youth is wasted on the young.
Duke137
Post Fri Sep 02, 2011 3:53 pm
Possibly a split hose is my first thoughts....
Jim320i
E30 Zone News / COTM Team
Post Fri Sep 02, 2011 4:01 pm
I'd suspect a hose too, once its warm, does it idle ok? I noticed on my chromie the other day it was idling really bad. Thought it was the valve timing I did the day before so suspected I hadnt timed them up properly... Then noticed the cable for the throttle body was sitting extremely loose and crookied, tightened that up and it was fine... So check over the throttloe cable as well. If you don't figure it out, we can have a nosey on sunday and see what we find.
Kedge
Post Fri Sep 02, 2011 5:10 pm
Can't find any sign of an airleak, intake boot is pretty new and I've sprayed a load of WD down to check the inlet manifold gaskets and no sign of anything there either.
It fairly warm at the moment and the coolant sensor is reading 571ohms.
At the moment while it warms it'll tick over nicely for 10-20secs and stall without warning, if I blip the throttle it'll attempt to hunt for idle again but really struggle and then stall.
Instagram - Kedge85
Post Fri Sep 02, 2011 5:15 pm
If you've ruled out airleaks I'd be pulling the throttle body off, clean it out with carb cleaner until its spotless, clean out and/or swap the ICV for a known good one and clean out/reset the TPS. If it doesnt cure your problems it is stuff that makes sense to do anyway.
Would suggest swapping the AFM for a known good one as well especially as the cover is/was missing you don't know what messing with it the previous owner has done
Kedge
Post Fri Sep 02, 2011 5:33 pm
Throttle body can be a job for tomorrow, I need a beer!
Found an ICV in stock but not sure how good it is though. Measured the resistance on both and they seem to rally with the guide at the top of the tech section.
Got two AFMs in stock but don't know what they are off, what part number should a facelift management AFM end in?
Instagram - Kedge85
Jim320i
Post Fri Sep 02, 2011 6:27 pm
Might also have a ICV over here mate, but would need to check. Not sure what type though but either from your engine or mine so you can try that out too if your unsure.
toby
Post Fri Sep 02, 2011 6:52 pm
Is the tps clicking when the throttle opens? Does the idle control valve hum with the ignition on?
Kedge
Post Fri Sep 02, 2011 6:53 pm
toby wrote:Is the tps clicking when the throttle opens? Does the idle control valve hum with the ignition on?
Yea both of those happen.
Instagram - Kedge85
Duke137
Post Fri Sep 02, 2011 11:05 pm
Has the car been used or stood around for a while?
Kedge
Post Sat Sep 03, 2011 1:50 am
It's been used in the last month or so but apparently been parked up for about 6 months prior to that.
Instagram - Kedge85
Post Sat Sep 03, 2011 7:14 am
Did you change the fuel filter the other day ?
Might be worth pulling the sender/fuel pickup thing out of the tank and checking the gauze isnt clogged with crap - might be clutching at straws but easy enough to do, it can't hurt and its free 8)
kman82
Post Sat Sep 03, 2011 9:01 am
Kedge wrote: It fairly warm at the moment and the coolant sensor is reading 571ohms.
If you're problems are when the car is cold youve got to test the temp sensor when cold. Edit: at the ecu end too
Kedge
Post Sat Sep 03, 2011 6:19 pm
Problems are when it's hot & cold. Was already warm last night when I was fiddling so couldn't check what the sensor was doing when cold.
Had the meter on it today and was reading 2804 ohms & 571 when warm. Is that within workable parameters?
It was had a new fuel filter on it Rob, not had time today to get in at the pump though but will give that a shot.
Today I did manage to whip the throttle body off, but I decided to swap it with the one off the chromie since I know that works fine. Now it's worse when cold, fires n dies without revs, still drives the same, ok on a good amount of throttle but kangaroos a bit on light throttle. :mad:
Instagram - Kedge85
**BANNED**
Post Sat Sep 03, 2011 7:07 pm
That's fine,now we need to check it's wiring,so repeat the check at the ECU plug.
What we are now trying to establish is the possibility of a poor connection at C191,the round connector under the inlet manifold.
toby
Post Sat Sep 03, 2011 8:15 pm
So the distributor cap and rotor arm are fine?
Kangarooing often seems ignition related.
Kedge
Post Sun Sep 04, 2011 11:18 am
Looks like I have an open circuit at the ECU, which pins am I looking at in particular on the C191?
Instagram - Kedge85
**BANNED**
Post Sun Sep 04, 2011 11:59 am
Kedge wrote:Looks like I have an open circuit at the ECU, which pins am I looking at in particular on the C191?
If you carefully peel back the rubber boot on the blue sensor,you will see the wire colours that you are looking for,at both C191 and ECU.
C191 splits off the engine loom,it carries the injector wiring and both blue/brown temp sensor wires.
Curr946
Post Sun Sep 04, 2011 12:04 pm
http://forum.roadfly.com/threads/387011 ... ost3870551
Pin# (Location) WireColor Size Function
1 (at three o'clock) BR/RD 0.5mm connects to coolant temp sensor;
from motronic control unit, pin #45 (coolant temp input)
2 (at one o'clock) BR/OR 0.5mm ground to coolant temp sensor;
from ground G103 on RH shock tower thru S701
Note that this is called a coolant temperature sensor,
not to be confused with coolant temperature sender.
3 (at eleven o'clock) BR/(BR/YL) 0.5mm ground to coolant temp sender;
from ground G200 under LH side of dash, above brake pedal
4 (at nine o'clock)BR/VI 0.5mm feeds the coolant temperature sender.
5 (at seven o'clock) RD/WT 2.5 hot side of the injectors
6 (at five o'clock) BR/WT 1.5mm connects to odd fuel injectors 1,3,5;
from motronic control unit, pin #16
7 (the center one) BR/YL 1.5mm connects to even fuel injectors 2,4,6;
from motronic control unit, pin #17
If your wife must learn to drive, don't stand in her way!
Kedge
Post Sun Sep 04, 2011 6:25 pm
Job done, was the AFM all along. Got one off Jim earlier and is running fine now, just maybe ticking over a bit high, can't remember what these tick over at bit it sits at around 950 rpm
Instagram - Kedge85
Jim320i
Post Sun Sep 04, 2011 6:27 pm
:cool: Glad to hear its sorted.
kman82
Post Sun Sep 04, 2011 7:19 pm
Kedge wrote:Job done, was the AFM all along. Got one off Jim earlier and is running fine now, just maybe ticking over a bit high, can't remember what these tick over at bit it sits at around 950 rpm
seems a bit high still mate, Did you say you've checked the electrics on the TPS?
Kedge
Post Sun Sep 04, 2011 7:23 pm
The TPS is off my other car which ran perfect so can't see that being a cause, throttle is fully closed on tick over to.
The open circuit I was seeing before was because I'd been thick and forgot to reconnect the plug to the temp sensor after rechecking that, only realised when I got to Jims and saw it hanging off :o:
Instagram - Kedge85
