My manual central locing has just started playing up and finally stopped altogether, can someone tell me where the relay is sited on a 325i convertible.
cheers
darren
central locking
DazzyA
Deep in the cill, under the driver's footwell speaker, but the problem is most likely with the driver's door pillar plug and socket.
Use the forum search function and look for central locking and red/black wires.
DazzyA
Thanks Brian will have a look.
faz
Try this link, it helped me sort out my problem.
http://www.e30zone.co.uk/modules.php?na ... ocking.htm
Faz
Faz
DazzyA
Thanks FAZ looks like just what i need.
darren
darren
Just had a quick read of that artical.
There should be a black plastic plate blocking off the void beneath the speaker,which looks like was missing from this car.
When you get the ECU out, before you do anything else, check to see if there is 12V + at the red/black wire going to the ECU. Check with a 12V lamp, not a meter. If this supply is not present, then leave the ECU alone, and find the two red/black wires going to the door pillar socket behind the speaker, and do as I have posted several times before.
If the 12V supply is OK, then have a look inside the ECU as detailed in the article. Note that the thermal trip is officially unrepairable, and fires have been caused by using the wrong solder.
DazzyA
Thanks for the warning Brian, I've just noyiced a sort of "buzzy" noise when I turn the key, sounds like it is coming from the relay, maybe just get a new i think.
Check the supply wire (red/black) to the ECU with a 21W 12V lamp.DazzyA wrote:Thanks for the warning Brian, I've just noyiced a sort of "buzzy" noise when I turn the key, sounds like it is coming from the relay, maybe just get a new i think.
Slight buzzing is a syptom of what I'm talking about.
DazzyA
Ok I'll try and get my hands on a lamp.
thanks Brian.
thanks Brian.
There are eight in your rear lamp clusters.DazzyA wrote:Ok I'll try and get my hands on a lamp.
thanks Brian.
DazzyA
Sometime i feel like the new kid at school, we all gotta start sometime,
thanks for the twelvetee time Brian, you don't want to come and lodge with us for a month or two?
darren
darren
Pass me the spanner
Might be the easiest way to sort your"wiring nightmares"
Haven't got time for that lot today. I'll have to print those pictures off and compare them with a half stripped car I have here.
DazzyA
Thanks Brian, i appreciate the help.
darren
darren
Pass me the spanner
