A/C Feed Problem
turkeysneck
Post Thu Aug 25, 2011 10:37 pm
The feed wire to the A/C pump isn't constant. It feeds for a split second them drops out again then a few seconds later it will come back and on it goes. Has anyone got any ideas.
It's an 86 325i.
mrLEE30
Post Fri Aug 26, 2011 8:18 am
the feed wire or the wire that tells the clutch to engage?
if its the latter then this only sends the "engage " signal when then temp is highre then set.
what colour is the wire?
turkeysneck
Post Fri Aug 26, 2011 12:25 pm
The wire that tells the clutch to engage, it starts off purple at the heater box then changes to black and white.
Not quite sure what you mean about higher than set ?
Post Fri Aug 26, 2011 2:21 pm
turkeysneck wrote: Not quite sure what you mean about higher than set ?
Aircon only actually works when instructed to do so by the thermostat attached to the temp. knob.
For your problem, check out what the pressure switches on the drier are doing.
turkeysneck
Post Fri Aug 26, 2011 7:19 pm
The problem is way before the pressure switches. I've fixed it now, it was a lack of feed to the temp regulator.
