hi all, back 2 months ago i had rebuilt my m2b25 to a m20b28 stroker. the car had started as a m20b20 and i had thought that the gearbox is the standard m20b20 one but when trying to fit the clutch that came with the 2.5 engine it would not fit. now i think the box is of a 318i or 318is but still could be the m20b20 one.
on the rebuild i had used a 290/290 cam and now i need a LSD.
what ratio LSD would you guys/girls recommend keeping in mind that the car is a 2.8 with a 290/290 cam.
also by putting a LSD can i use my original drive shaft and prop or will they both need changing
all the help would be appreciated
lsd help
aceifty
anyone as im
dont no which one to go for
1989 cab M20B28 build
aceifty
there's gotta be someone out there with some idea
I'd be going 3:64. The engine should have the legs to handle it and will give the lowest revs and best MPG on a run.
I'd say a 3:91 would be to low.
As long as it's an e30 Diff, the unit should will bolt straight in.
M3 diff mount is a good tip before fitting.
aceifty
as far as i no the diff that iv got at the moment is the standard m20b20 one 4.27 which is a small case diff, if i put the 3.64 LSD will i need to adjust the prop, as iv been told that i will need to adjust the prop length, is that correct.B7 wrote:I'd be going 3:64. The engine should have the legs to handle it and will give the lowest revs and best MPG on a run.
aceifty
come on guys, there's got to be more than one person
e30-EVN
yes you will need to adjust the prop length mate, there is not a great deal in the amount you need to shorten it but it will need doing
btw, im running a 3.64 lsd on my m52 and its great, your m20b28 will have the legs for the longer ratio and as said will return good mpg's on a run also.
it has been said that a 3.64 is a bit long for a standard m20 and that 3.91 is the better ratio but this wont be an issue on your lump!
hope this helps
hope this helps
I actually like the 3.64 in a 2.5. I ran one in my convertible (which came standard with a 3:73) with no issues.
Now I've got the 2.7, it's perfect. Si13 is running a 3:73 in the Alpina C2.7 touring and even he's considered a 64.
aceifty
thanx for the help guys
