lsd help
aceifty
Post Sun Aug 21, 2011 7:21 pm
hi all, back 2 months ago i had rebuilt my m2b25 to a m20b28 stroker. the car had started as a m20b20 and i had thought that the gearbox is the standard m20b20 one but when trying to fit the clutch that came with the 2.5 engine it would not fit. now i think the box is of a 318i or 318is but still could be the m20b20 one.
on the rebuild i had used a 290/290 cam and now i need a LSD.
what ratio LSD would you guys/girls recommend keeping in mind that the car is a 2.8 with a 290/290 cam.
also by putting a LSD can i use my original drive shaft and prop or will they both need changing
all the help would be appreciated
aceifty
Post Sun Aug 21, 2011 9:42 pm
anyone as im :? dont no which one to go for
aceifty
Post Mon Aug 22, 2011 2:16 pm
there's gotta be someone out there with some idea
Post Mon Aug 22, 2011 4:23 pm
I'd be going 3:64. The engine should have the legs to handle it and will give the lowest revs and best MPG on a run.
I'd say a 3:91 would be to low.
As long as it's an e30 Diff, the unit should will bolt straight in.
M3 diff mount is a good tip before fitting.
aceifty
Post Mon Aug 22, 2011 4:47 pm
B7 wrote:I'd be going 3:64. The engine should have the legs to handle it and will give the lowest revs and best MPG on a run.
as far as i no the diff that iv got at the moment is the standard m20b20 one 4.27 which is a small case diff, if i put the 3.64 LSD will i need to adjust the prop, as iv been told that i will need to adjust the prop length, is that correct.
aceifty
Post Mon Aug 22, 2011 5:23 pm
come on guys, there's got to be more than one person
e30-EVN
Post Mon Aug 22, 2011 5:41 pm
yes you will need to adjust the prop length mate, there is not a great deal in the amount you need to shorten it but it will need doing
btw, im running a 3.64 lsd on my m52 and its great, your m20b28 will have the legs for the longer ratio and as said will return good mpg's on a run also.
it has been said that a 3.64 is a bit long for a standard m20 and that 3.91 is the better ratio but this wont be an issue on your lump!
hope this helps 8)
Post Mon Aug 22, 2011 7:14 pm
I actually like the 3.64 in a 2.5. I ran one in my convertible (which came standard with a 3:73) with no issues.
Now I've got the 2.7, it's perfect. Si13 is running a 3:73 in the Alpina C2.7 touring and even he's considered a 64.
aceifty
Post Mon Aug 22, 2011 7:55 pm
thanx for the help guys
