DIY HEAD GASKET.
palerider325icab
Post Tue Aug 30, 2005 6:22 pm
Cheers m8 i was just wondering i thought all the blocks where the same,why wont it work.
Cheers. :D
TOURINGDADDY
Post Tue Aug 30, 2005 8:20 pm
pistons and valves different, share the same block sort of
oze30
Post Sat Nov 05, 2005 9:19 pm
So in essence, You remove rocker cover, undo star nuts, remove head?? Im thinking about regasketing my head.. Is there any detailed info on this procedure?
Post Sat Nov 05, 2005 9:23 pm
try www.bimmerdiy.com/e30 should be a section on headgasket swap, plus loads of other useful info :wink:
m-dtech
Unapproved Trader caution
Post Sat Nov 05, 2005 9:28 pm
i have a 320i head thats yours for Ԛ£50.
postage you can arrange your self at parcelforce.com 48hr service is good.
engine is from a 520i with 79k miles on the clock.
oze30
Post Sat Nov 05, 2005 10:02 pm
I have a 325. is it any different?
Gunni
Post Sun Nov 06, 2005 1:07 am
Swap in a 2.5
This is the perfect time.
And the 2.5 engine shouldnԚ´t cost you to much,
also get wiring, ecu and intake and exhaust if yours isnԚ´t double.
170hp is waiting for you ;)
With great challenges comes great engineering.
Gunni
@ 2012 VEMS group buy !!
Toby_Unna
Boost Junkie
Post Sun Nov 06, 2005 2:07 am
Gunni wrote:Swap in a 2.5
this thread is old and the 320 in question is long gone due to rust and does not need a 2.5 in it :wink:
