elp!!! m20 early 2.5 conversion car wont start..........
MOODY
Doesn't make sense! Does it start or doesn't it? Or do you mean oit won't start from the key?MOODY wrote: i have sparked it of the starter and it starts, any ideas what it could be?
punko
check the wiring on the starter make sure you have the 2 smaller wires the right way around, if so check what happens at the wire from the ignition barrel with a multimeter.
MOODY
brian it wont start from the key, and its only got 1 small wire on the starter, and 2 on the + plus
Are you using a facelift or pre facelift loom with this engine?
If facelift, is it the one that was in the car before the engine swap?
MOODY
ive used the pre facelift mate?Brianmoooore wrote:Are you using a facelift or pre facelift loom with this engine?
Then about the only thing that can be wrong is you haven't connected the black/yellow from the loom to the correct terminal on the starter motor.
Black/green is best connected to the 13mm nut closest to the starter motor body.
