coilover coil dislocation and MOT
nickso
Post Mon Aug 15, 2011 5:03 pm
Am i right in thinking MOT blokey will fail me for spring dislocation on coilovers? Seem to remember reading that somewhere.
If so has anyone got a supplier of some helper springs? Seems it's Faulkners or Faulkners from a quick search.
'88 e30 328i M52 track bint.
HairyScreech
Post Mon Aug 15, 2011 6:18 pm
could you not wind your coil overs up? i know it would give a daft ride height, but its only a case of winding them back down again.
nickso
Post Mon Aug 15, 2011 6:29 pm
I thought of that but I'm not sure they will go high enough, the rears in particular dislocate by a long way. I will probably put them up anyway to stop any car/ramp interaction so I might have a play tomorrow.
320Touring
Post Mon Aug 15, 2011 9:45 pm
Cable ties FTMFW!
Failing that, helper springs as you say.. or just refit stock rear dampers/springs?
nickso
Post Tue Aug 16, 2011 2:40 am
Standard stuff is currently suspending Jakes touring so no chance of that. Cables ties though....hmmm....or perhaps some duct tape. :)
shedrool83
Post Tue Aug 16, 2011 6:57 am
Got shocks and springs here Nick you need them for the mot.
Shock are new from a cheap e36 coilover kit so they wont fail.
If you need them mate just give me a shout.
Prey
Post Tue Aug 16, 2011 9:25 am
it shouldn't fail the mot on a spring dislocating - only if it doesn't relocate on its own iirc.
bmwbmwbmw
Post Tue Aug 16, 2011 6:17 pm
my brothers e30 passed the mot with his coilovers on
89' e30 cabby (road project)
89' mazda 323 turbo 4x4 bf (road project)
89' mazda 323 turbo 4x4 bf (died, it still has its place in my hart) im really sorry for abusing you, please forgive me
99' 525i sport manual with m5 bits (daily driver)
aceifty
Post Tue Aug 16, 2011 8:06 pm
iv got coilovers on my cab and it passed the MOT, was told it is a bit to low but still ok cuz the cab is sitting on coilovers.
Post Tue Aug 16, 2011 10:46 pm
If the spring noticeably falls out it will fail, I doubt a keen eyed tester would pass it with cable ties holding the spring in. E36 dampers are longer BTW, so the spring will drop more.
nickso
Post Wed Aug 17, 2011 1:27 am
OK it's only the rears that do it so I'll order some helpers and adaptors and do it properly.
Next thing I'm wondering if it will get on the fecking ramp as the front springs are too short meaning it has very little adjustment, it's pretty fecking low and it's wound right up to the top of the thread. :roll:
Post Wed Aug 17, 2011 8:30 am
You could pack out the rears with some extra rubber pads if its not that much of a gap
nickso
Post Wed Aug 17, 2011 9:13 am
It's not using the balloon springs now Dan, it's coilover on the rears now too. It's exactly 2" of a gap at its current ride height so a couple of 2" helpers and the adaptor thingy should sort it, I'm guessing they are 2.25" springs, doubt 2.5's would fit on an e30.
Post Thu Aug 18, 2011 1:00 pm
Sounds counciltastic ! :)
nickso
Post Thu Aug 18, 2011 1:38 pm
Extremely Pete. I'll probably have it down in Englandshire one summer so you can take the pish with no mercy. :)
